This is my first post. I recently acquired a used GA42RVT for what I thought was a good price. However, it appears to have some problems.
1. It seems heavily tilted toward the bass.
2. Reverb is VERY weak, and neither Reverb nor Tremolo appear to work as described in the owner's manual. Both are present with or without the foot switch, and both are present on both channel 1 and channel 2 to some extent, instead of just on channel 2 or in mix mode.
3. Low volumes aren't really possible. The transition from no volume to volume is very steep.
Problems are present in both the Pentode mode and the Triode mode, but may be worse in Triode mode. Problems are definitely worse when guitar output is high.
I've searched on this forum, and found some threads related to this amp. There was a schematic posted, and then further posts indicating that the schematic was wrong, along with hand drawn corrections for some sections.
I took the amp to a repair shop today. In a few minutes of playing an old telecaster through the amp, the technician recognized what he said was a microphonic 12AX7, and a runaway 6L6. He seemed to be knowledgeable, although he had not worked on one of these before.
He asked me if I had a schematic, and I told him about what I'd read here.
Does anyone have any further information about this amp and its problems, or a final version of the schematic that could be shared? I am in the mode where, if it could be fixed, I would keep it. If its a lost cause, then I would return it to the seller.
Any insight or advice? Thanks in advance.
