Line-in confusion
  • Line-in confusion
    Hi. I’m a newbie so please excuse my ignorance here… I have a Behringer GMX212, which is more than adequate for the few chords and scales that I have learnt so far.
    Having played with a few stomp boxes and effects processors, I’m no longer happy with the amps limited effects and “dodgy” amp models. Also, the amp is a bit noisy. There’s a fair amount of hiss when you turn up the treble, even on the low gain tweed mode. The hi-gain modes sound really noisy.
    So I plugged my guitar into the AUX-IN which seems to bypass the EQ and effects – but leaves the volume control working. This helped a bit, but there’s still some noise (preamp noise?) when you turn up the volume. I then plugged my my distortion pedal's “out” into the “slave-in” and weh-hey! It completely bypasses the pre-amp and master volume control (hardly a problem as my pedals have EQ and level) and it sounds so much better! Much more open, (more spacey, less compressed) clearer and absolutely zero hum & hiss – unless I jack up the gain on the distortion pedal but even then it’s less hissy.
    My question is… am I doing anything seriously wrong? Everything has worked fine so far, but I’ve just ordered a Boss ME-70 (gets here next week) and I’m concerned about breaking it. I could run it in stereo via the aux-in or slave-in, but I think slave will sound clearer. Obviously the master volume control on the pedal will have to be used to control the amps volume, but I think it’s a small price to pay for such a clear sound.
    Any help would be greatly appreciated as I’ve Googled this to Hell, but to no avail.
    I don't think so. Most tube equipment to my ear hisses like a snake, even in spite of what some others have seem to preach to me about. -sorry
    -g
    Gary Moore
    Moore Amplifiication
    mooreamps@hotmail.com
      No, it won't break anything. The slave in just bypasses all of the preamp circuitry and goes straight into the power amp.
      Mooreamps, the GMX212 doesn't have a single tube in it.
