Crate BV120H bias?
The 70% idle dissipation figure is a mythical catch all. For a lot of amps with higher plate voltages it is way too hot.
There is no single % number that is good for all amps. Single ended amps usually run about 100%. Many newer high gain amps run the power tubes as low as 25%.
Although the 70% figure is probably ok in this case, the factory setting (see post #5) is lower and will give longer tube life.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by g-one View PostThe 70% idle dissipation figure is a mythical catch all. For a lot of amps with higher plate voltages it is way too hot.
Although the 70% figure is probably ok in this case, the factory setting (see post #5) is lower and will give longer tube life."Reality is an illusion albeit a very persistant one " Albert Einstein
The Peavey 5150 is a good example of cool power tubes. At 480-500v B+, the tubes in a stock amp are conducting in the 11ma to maybe 20ma tops depending on tubes. That power amp is clean and strong, they get the tone in the preamp.Education is what you're left with after you have forgotten what you have learned.
Originally posted by Enzo View PostThe Peavey 5150 is a good example of cool power tubes. At 480-500v B+, the tubes in a stock amp are conducting in the 11ma to maybe 20ma tops depending on tubes. That power amp is clean and strong, they get the tone in the preamp."Reality is an illusion albeit a very persistant one " Albert Einstein
Originally posted by TomCarlos View PostThanks again guys... I will revisit your replies here and go back and reset the bias. At this point, it is a learning curve for me!! Tom"Reality is an illusion albeit a very persistant one " Albert Einstein
The Peavey 5150 amps are an exception to the rule of biasing.
There is an article on the net, by Peavey's own Roger Grimm, where he explains the why of the fact that the 5150 bias is set very low.
In a nut shell, all of the distortion is in the preamp.
The Resonance control (bass response at different volumes) depends on the low bias.
Roger's articles: Tech: Ninety Nine Days-Roger Crimm
Ive never correlated plate voltage (or heard of doing so ) with way cooler bias.
Yes, the 5150 is at the end of the scale, but it demonstrates that bias can be a very wide range and still perfectly fine. 70% is nothing more than a place to hang your hat.Education is what you're left with after you have forgotten what you have learned.
Originally posted by Enzo View PostI didn't correlate the two, but we were talking low percentage bias dissipation, and without that voltage those currents won;t tell you that. So I included the plate voltage typical in those amps so you could see that 14ma - for example - at 500v is 7 watts, or 23%.
Yes, the 5150 is at the end of the scale, but it demonstrates that bias can be a very wide range and still perfectly fine. 70% is nothing more than a place to hang your hat."Reality is an illusion albeit a very persistant one " Albert Einstein
Ok read it but he doesn't really explain much about how much crossover distortion is "severe" or why it's a good thing for the 5150. He does go on to say that to cold is not good either.
Honestly its hard to put rhyme or reason to some things. For instance my Mesa DC3 is non adjustable fixed bias with 400pv and -11 grid voltage running EL84s. Basically that means by design it ran any tubes crazy hot.(130+%) I modified the bias and cooled it down to 80 % . Who's right? Sometimes I just don't know.lol BobLast edited by rockon1; 02-03-2014, 02:53 PM."Reality is an illusion albeit a very persistant one " Albert Einstein
Originally posted by rockon1 View PostAgreed. The hat sits on 70% as the end of the line go no further not this is where it has to be imo. I'd like to see that article thiugh. 23% seems silly. Not after power tube or pi distortion but some modicum of efficiency. From all I've read 25% would be deep into crossover distortion territory. Bob
And then listen to it.
A Class B amp would sound raspy & bad. (severe x over)
But add a small amount of bias to slightly turn the tubes on & wallah.
Class AB.
My question is: 'why go any further with the bias'?
What is the benefit?
Originally posted by Jazz P Bass View PostHave you used a scope to actually observe 'crossover distortion'?
Class AB.
What is the benefit?"Reality is an illusion albeit a very persistant one " Albert Einstein
Originally posted by rockon1 View PostIve never correlated plate voltage (or heard of doing so ) with way cooler bias.
Many manufacturers exceeded max plate voltages by wide margins. They got away with it by running cool bias, like 50%. A couple examples, Musicman and Ampeg V4. Often the amps did not have adjustable bias. Now everyone takes those amps, installs adjustable bias, set them to 70% without even checking what the stock value was. Then when the tubes are short lived, they blame the high plate voltage and ask why they don't build tubes like they used to . How about "we don't bias tubes like they used to" instead?
Remember Aiken's Wombat bias tool? Instructions were to not exceed 70% with plate voltage lower than 420V, do not exceed 50% with plate voltage over 420V. Here's what you said about it
"rockon1
12-15-2010, 07:41 PM
Well all I can say is that the Wombat appears to be a well thought out,superior product! Bob" (Compu-Bias vs. Aiken Wombat [Archive] - The Gear Page).
Originally posted by g-one View PostI have read on this forum and elsewhere warnings about cooling bias down when plate voltages are higher. Also the idea that it is not high plate voltages that kill tubes, but high plate dissipations.
"rockon1
[ATTACH=CONFIG]27304[/ATTACH]
I didn't read the instructions for the Wombat but Aiken is OK with high plate voltages and higher dissipation as long as the primary impedance is taken into account. He also states basically anywhere from 50-70% which I concur with.From his biasing page.
"A general rule of thumb is that class AB amplifiers are usually operated at no more than 70% of the maximum plate dissipation of the tube (to account for the higher dissipation that occurs under signal conditions), while true class A amplifiers generally run right at the maximum plate dissipation (the dissipation at full power is lower than the dissipation at idle in a true class A amplifier). For example, the aforementioned EL34 tube has a plate dissipation of 25W, so at 400V class AB operation, it should be biased no higher than (0.7 * 25/400) = 44mA. This doesn't mean you should automatically bias all tubes to 70% of max dissipation! They can be biased at any lower current if desired, and many people prefer a point of around 50% to 60% of the max plate dissipation, which contributes to longer tube life. In addition, the "70% rule" falls apart as you use very high plate voltages, unless the primary impedance is increased accordingly. In some cases, if the voltage is high enough, there is no bias setting that will result in safe operation without exceeding the maximum plate dissipation of the tube. For example, in a 100W EL34 amp with 480V on the plates and a 1.7K primay impedance, there is no bias setting that will keep the output tubes from redplating at some point in the power curve, even if you bias the amp at 0mA! If you double the primary impedance to 3.4K, however, the amplifier will operate fine at all power levels, and you can bias it all the way up to 52mA without ever exceeding the plate dissipation at any point in the operating curves. This may sound odd, because the bias point is right at 100%, but it works because of the very high plate impedance load, which never allows the tube dissipation to increase above the idle level. It also may not sound as good, because the screen voltage should ideally be decreased so the loadline intersects the "knee" of the curves if not, the nonlinearity increases drastically. The bottom line is that you have to take into account not only the plate voltage and plate current, but also the primary impedance to find out the safe bias area."
So yes there is more to take into account than PV and current. One size doesn't fit all but I didn't say it did. That said if the "proper" primary impedance is used then according to Aiken 70% is ok with high PV. Now that said -if an amp sounds good at 50% then leave it at 50%!
BobLast edited by rockon1; 02-03-2014, 08:40 PM."Reality is an illusion albeit a very persistant one " Albert Einstein
