Results 1 to 7 of 7
Thread: Guitar cable & solder
    Junior Member
    Jan 2010
    9
    0
    hello, what is the best solder to use for guitar cables ?
    thx fret
    Old Timer defaced's Avatar
    Dec 2006
    York Pa
    1,394
    15
    I would go for a standard lead/tin rosin core electrical solder. Probably 0.032 to 0.062in diameter. Your local RadioShack should have it in small quantities.
    Last edited by defaced; 01-20-2010 at 04:07 PM. Reason: Mixing welding wire and solder wire diameters.
    -Mike
    Old Timer
    Jun 2006
    3,315
    Received: 1/0
    17
    ...and remember to physically stake the shield/ground conductor to the plug's ground tang when soldering, don't just let it rest there under it's own weight.
    Senior Member guitician's Avatar
    Aug 2008
    Phoenix
    1,009
    13
    Here's another tip.....leave some slack on the center conductor wire. If you run it straight to the tip connection it will eventually break from stress.
    May 2009
    36
    0
    Good information,
    I recently worked with a cord that was part straight and part coiled. It had a break 18" from the plug in the straight portion. I removed a section and did a pretty nice looking splice & used 2 metal 1/4" phone plug covers/ferrules to shield and cover
    It had some of the strangest wire I have ever dealt with in 30 years of messing around with electronics, never seen anything so strange. Hard to get the wire clean enough to solder, had some sort of coating.
    Junior Member
    Jan 2010
    9
    0
    thx for the response,
    i seen a guy use liquid flux, is this bought or do you think he liquefies the regular flux? thought it was useful to soak into the wire for pre-tinning?
    May 2009
    36
    0
    Quote Originally Posted by fretboard12 View Post
    We have some Kester All Purpose Soldering Flux that is liquid (pink) I have used it to soak poor quality solder wick before and it helps it work much better.
  1. Replies: 8
    Last Post: 12-02-2009, 04:13 PM
  2. Replies: 20
    Last Post: 07-14-2009, 10:40 PM
  3. Guitar cable question
    By if6wuz9 in forum Music Electronics
    Last Post: 05-16-2009, 12:28 AM
