Hall Effect Sensor?
  • Hall Effect Sensor?
    Hi
    I am in the process of making a new counter for my winder and I have a question.
    How do I connect the the hall effect to my counter? I am out of ideas, what to I connect and where?
    The counter is an electronic counter kit, I have assembled it and it works great.
    Here is more info on the kit, including schematic.
    http://www.oceancontrols.com.au/coun...imers/k129.pdf
    Here is the hall effect I have and some info on it.
    http://blast02.lns.mit.edu/targets/i...legro_3503.pdf
    Dave
    Originally posted by Dave293 View Post
    Hi
    Four digits isn't really enough for pickups, where one can have more than 10000 turns. Five digits are a better choice.
    Wrong hall sensor. This one is linear, intended for measuring the magnetic field and yielding a voltage that varies smoothly and proportionally with magnetic field, while the counter expects a binary logic signal. One can make this work, but some added circuitry is needed to generate the needed logic signal when the hall-sensor output voltage passes a specified threshold.
    There are hall sensors (from Allegro and others) that contain the necessary logic and yield a binary output signal, well suited to driving a counter (if the voltage levels are matched).
    Perhaps a CUB3 counter and a reed switch would be the quicker way home.
      Hi,
      As the hall sensor you have is linear, then you'll need to convert the output to a -Ve going pulse for the clock input using a comparator as shown here:
      http://ecow.engr.wisc.edu/cgi-bin/ge...317lab6fan.doc
      The magnet polarity is important.
      HTH
      S.
        Joe, the K129 wraps to 0 and continues from there once reaching 9999. I may be mistaken, but that doesn't sound like an issue to me, wind to 1000 after 9999, unless the overflow causes some other problem.
        Regards,
        Michael
        int main(void) {return 0;} /* no bugs, lean, portable & scalable... */
        www.ozbassforum.com
          As said this counter starts back at 0 after 9999 or you can add 2 of these counters together and have an 8 digit counter if needed.
          I bought this hall sensor as it was the only sort I could get locally. Maybe a reed switch would be a better option.
          Thanks everyone for the help!
            Sounds workable, but a bit clumsy.
            It's the locally that's the problem. Unless you are very fortunate in your location, it's pretty much essential to use the catalog distributors like Mouser, Digi-Kay, Allied, Newark, et al. These companies have at least ten times the selection of even the largest of brick-and-mortar stores, and collectively they exceed brick-and-mortar by a factor of 100.
            The disadvantage is that their catalogs are pretty big and intimidating, making the web interface almost useless if you don't know exactly what you are looking for. So, order the paper catalogs (which are free), as browsing is far easier in a book.
              Thanks!
              I though about ordering from mouser but I have some pickups I want to mind now and didn't really want to order just a hall effect and maybe some eyelets all the way from the US I'll wait to I have a bigger order and order the right one then, for the time being i'll use a reed switch.
                It does work and it's much cheaper than the cub counters.
                www.ozbassforum.com
                  Micheal,
                  If you're looking at CUB's locally they are expensive but you can get a used CUB3 on ebay for $20 and get it shipped to you. With shipping I paid $35 for mine and it was a great investment. The guy also made money shipping it to me because that thing weights no more than 100 grams.
                  www.MaillouxBasses.com
                  www.OzBassForum.com
                    Originally posted by Phil m View Post
                    Micheal,
                    Ok, sounds like a good deal Phil. I'll keep an eye out for them.
                    www.ozbassforum.com
                      It's that locally again. They cost $31 new from Digi-Key: http://catalog.digikey.com/scripts/p...?name=RLC03-ND.
                      One thing I like about the CUB3 is that they have user-replaceable batteries. The counters with built-in lithium batteries are disposable, as the batteries cannot be replaced without surgery.
                        Micheal's in Sydney, Australia. That's why I suggested ebay as I got mine from there. There's a Red Lion distributor here, however you're looking at $60-$100 AUD for a CUB.
                        Thanks for the digi-key tip though. $31 is cheap and I'll probably get another one soon
                        www.OzBassForum.com
                          Ok, here is a rough estimate of the cost looking at the product and international shipping prices at the Digi-Key web site:
                          CUB3: USD$31.32
                          Shipping to Aus (USD$18 - $32 depending on destination, estimate only): USD$20
                          Processing fee on all international orders except Canada: USD$6
                          Total: USD$59.32, AUD$75.19
                          So, not really better than buying local (Australia) it seems.
                          www.ozbassforum.com
                            CUB3: USD$31.32
                            The AUD is 0.7887 USD, so USD $31.32 becomes AUD $39.71, not AUD $60-$100, so it seems that the price in Australia is significantly higher than the US. Shipping in bulk is very cheap, so that isn't the reason. More likely, it's the lack of competition in Oz.
                            The real issue with locally is the lack of selection and of competition. Shipping is less of an issue if one doesn't have to cross the Pacific Ocean, but still most of that USD $20 is per-order overhead, so one would benefit from fewer, larger orders. And slow delivery is cheaper.
                              Joe, not sure what you mean about it not being AUD $60-$100. If you look at my post above, you'll notice that it is the total cost including shipping and the international processing fee. I recalculated it today and the total is AUD$72.59. Also, the cheapest shipping Digi-Key offer is via United States Postal Service Global Express Mail @ USD$18. As you say, shipping in bulk may be cheaper, but it's relative. There is no way we're are going to get it cheaper than that (shipped to Australia) from Digi-Key. Local to the US is cheap for this product, not here.
                              I agree with this to a certain extent and possibly in this case. But, what I've seen, is that it is rare to get a really good deal here at all.
                              Regards,
                              Michael
                              www.ozbassforum.com
