Results 1 to 9 of 9
Thread: Fender Blues Junior Harp mods
    Junior Member Watto's Avatar
    Jun 2006
    Australia
    20
    0
    Does anyone know of some harp mods to lower feedback on these amps.
    If you change the input load resistor to 5M like in say the bassman ,is this going to work.I've got the schematic and I'm guessing the resistor in question is R2.
    I'm new at this and was wondering if I'm on the right track
    Cheers
    Mark
    Old Timer
    Jun 2006
    3,315
    Received: 1/0
    17
    Increasing the input load won't really reduce feedback, it will improve sensitivity.
    There are 2 Blues Jr schematics, pre '01 and Mar '01 onwards. Many resistor cap numbers are completely different from one to the other. So if your amp is pre '01, then yes R2 is the input load.
    However, these amps have a TON of gain so I'm not sure that it's the best basis for a harp amp. That said, you could try snipping the bright cap off the volume control (C2), if you can live without the fat switch try snipping C4, reduce the size of the feedback resistor (R27-say add 47K in parallel?), go a little larger at R13 (add 22k in series)?
    Of course there are also preamp tube subs to try & rebiasing?
    All these are easily reversible if things don't work out.
    Jun 2006
    Australia
    20
    0
    Thanks for that MWJB
    I'll give them a go and let you know the results.
    Cheers
    Watto
    New Member
    Jun 2006
    Portland
    5
    0
    Swap preamp tube
    Simple mod is replace 12ax7 with 12at7 or 12ay7. This will reduce the gain and help with feedback a bit. Some like to drop the preamp B+ to around 90-100v by increasing the resister between the last 2 filter caps. Larger bypass and coupling caps for more bass also helps for harp.
    Feb 2007
    Bålsta
    64
    13
    I cut off the c1-cap and change r1 to 100k.
    That leaks out the signal and increased gain a bit.
    Change speaker to a harpfriendly speaker. A Jensen or Weber Alnico.
    Then you do some tubechanging experiments.
    Dec 2008
    22
    0
    blues jr
    i use a blues jr for practice and find that if i match it with the right mic(i use a shure 707 with r7 element)it works great out of the box but for gigging the 64 vibrolux reverb is the thing...but try different mics.
    Junior Member the wizard's Avatar
    Jul 2007
    18
    0
    Sell It!!
    Sell it and get a Pro Junior & a Lone Wolf Harp Delay Pedal.
    Go you Rick Davis's site for info:http://www.bluesharpamps.blogspot.com/
    Or, save your money and get a Harp Gear Double trouble.
    Dec 2008
    22
    0
    cut the c-3 cap and change the no 1 tube to a 5751 and speaker if you like...i didn't change the speaker but the sound is excellent
    Feb 2007
    Bålsta
    64
    13
    Since 7 years back my last post here have been wrong. It should be C3! If you cut c1 it be quiet.
  1. Slight problem with my Fender Twin Reverb.
    By Humbucker in forum Vintage Amps
    Last Post: 06-20-2013, 10:30 PM
  2. Phase 90 mods
    By tuberattler in forum Guitar Effects
    Last Post: 12-15-2008, 06:11 AM
  3. Vacuum Tube Harp Amps!
    By Bruce / Mission Amps in forum Harp Amps
    Last Post: 01-21-2008, 06:12 PM
  4. Over driven Harp sound?
    By andrew4566 in forum Harp Amps
    Last Post: 06-10-2006, 07:11 PM
