Mackie SWA 1501 fuse blowing
  • Mackie SWA 1501 fuse blowing
    I am working on a Mackie powered subwoofer and it is blowing F2, The one connected from Center Tap to ground, when powering down. I have checked through all the transistors and diodes with no luck.
    I have a question about the LEDS on the main board.
    LED 15& 16 are lit.
    Under normal operation should D44,D42 & D34 be lit, currently (no pun) they are unlit.
    Have a good weekend all!
    Helping musicians optimize their sound.
    Hi wholetonemusic.
    Why don't you move this post (or re-post) on http://music-electronics-forum.com/t16267/ where a couple of these Mackies are being repaired?
    It would help all.
    Thanks.
    EDIT: post the schematic if you have one, we are working with a partial one only (the LF power amp)
      Thanks, Will do.
