5e3 O.T question
  • 5e3 O.T question
    Hi, I already own a Mission 5e3, totally stock, and love it. I want to build another one similar to it and was wondering about the OT.
    I have on hand a 35 watt (pro reverb?) OT. with a primary of 4000 ohms and secondary of 4 ohms. If I run an 8 ohm speaker would the reflected primary be 8000 ohms on the 6v6 tubes?
    Will this work in a 5e3 circuit, or should I look for another OT?
    Thanks.
    Yes the primary Z will match 6V6 into an 8ohm load.
    A 35W OT is obviously a considerably bigger unit than the stock type OT, but as you have it, I'd give it a go.
