No Sound on Fender Twin Pro All tube
  • No Sound on Fender Twin Pro All tube
    Hi, I'm new to the forum. And, I am desperately in need of some advice.
    I bought a used fender twin all tube about 6 weeks ago. It's my first tube amp, so I'm lost. I have been using it frequently in-studio at low volume on the 1/4 power setting to reduce bleed over on the drums. Today I switched to the full power setting to run through a song live before recording, halfway through the song the amp cut out...to almost no sound. The red LED was still on and the amp still had a low volume hiss. But, there was no actual guitar signal coming through on either setting (1/4 or full power). Not sure if it is a bad tube(s) or what. Also, no signal coming from Pre-amp output or effects loop. The main power fuse is in working condition. I had a few extra tubes...so I replaced each tube, one at a time, tested it, and tried the next.
    Has anyone else had this problem? Or, have an idea of what may need to be changed.
    Any help will be greatly appreciated.
    Thanks,
    Steven
    Try reading through this:
    Tube Amplifier Debugging Page
