roland JC 77
  • roland JC 77
    does any one have the schematic?
    thanks
    JC-77 Schematic
    Here it is.
    PLEASE NOTE: The person that scanned this apparantly thought it was a JC-120 schematic and labled it as such, however it is really a JC-77 amp.
    You can tell by the single channel and the hi-treble pot.
    By the way, this schematic is from 1984 and I am sure that you probably know that Roland made quite a few changes to this circuit over the years.
    It may not be identical to the amp that you have.
    Steve
      Thanks Steve!!
        As far as I know, that IS indeed a schematic of a JC-120. Not the combo model, though, but the head.
        See:
        - The same power amp circuit as in most JC-120's (wouldn't make any sense if it was a schematic for the lower power JC-77 version)
        - Sub in jack and four speaker output jacks. No such things in JC-77 but indeed found from JC-120H.
        - No speaker depicted in schematic although all Roland's JC-series combo schematics depict them.
        - Overall the same features that the JC-120H head has (which are also features shared by the JC-77, hence the confusion)
        I'm sorry to say it, I believe that is not the right schematic for JC-77.
        Hopefully it will help, though because likely the preamp design in both is very similar.
          Was the High Treble control feature on any of the JC-120s?
          Just curious.
            The JC-120H is, as far as I know, the only JC-120 amp that has it.
              http://music-electronics-forum.com/t37207/
              And here's the owners manual for no particular reason !
              JC-55_77_Owners Manual.zip
