Results 1 to 17 of 17
Thread: Custom Name Plates
    Junior Member
    Feb 2010
    9
    0
    Custom Name Plates
    Hi, I'm new to the Forum and am in the process of putting together my first amp, a Mojotone 5F1 and I would like to have a name tag on it with my name when I complete it similar to a Fender tag that comes on their Amps. Any place that you may use to get a metal tag that is custom.
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    10,966
    Received: 1,103/15
    Given: 827/23
    25
    Name tags can be made with different technologies, please post a photo of the one you'd like to reproduce with your own logo.
    Junior Member
    Feb 2010
    9
    0
    I don't have a Logo so much as using my name in a font.
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    31,391
    Received: 1,315/7
    53
    An image is an image, post your font and text then.
    Oct 2007
    10,966
    Received: 1,103/15
    Given: 827/23
    25
    Maybe I was not clear.
    What I mean by different technologies is that nameplates can be Zinc Cast (Fender 60's to present day), plastic injected (Marshall), Plastic engraved/milled (Hiwatt), silk screened , (Photo) chemical etched/anodized (Blackface panels), cut from flat sheet metal (real old Fender) , or Laser Engraved.
    Some of these can't be one-offs, (the first two), others have differing degrees of difficulty.
    I personally silk-screen mine, but as you want only one or two, Laser gives excellent results.
    Google "laser engraved panels"
    You can also use a cutting-plotter made one.
    Junior Member
    Feb 2010
    9
    0
    Well I found a site that makes the name plates and placed my order.
    Noodle of Reality Steve Conner's Avatar
    Glasgow, Scotland
    7,251
    Received: 13/0
    22
    Weber VST made a batch of these for me. I just sent them the font.
    Oct 2007
    10,966
    Received: 1,103/15
    Given: 827/23
    25
    Hi Steve, sorry to bring bad news, but that font is called (Engraver's) Old English
    Didn't you have something a little more .... Scottish?
    Or Celtic at least?
    Now on to the serious part: I think we deserve a few other pictures of your gorgeous amp, or at least the front panel.
    Congratulations.
    Glasgow, Scotland
    7,251
    Received: 13/0
    22
    Pic attached! Sorry, but the old English Gothic script just looks more metal than anything Celtic. It's actually a "Fraktur"
    http://en.wikipedia.org/wiki/Fraktur_%28script%29
    I've written up some information about the amp too.
    scopeblog Ninja Deluxe
    The only downside with Weber's laser engraving is that he has a minimum order. I ended up with 8 nameplates, and only 2 amps to put them on. I put one on my front door, so I just need to make another five amps.
    Oct 2007
    10,966
    Received: 1,103/15
    Given: 827/23
    25
    Beautiful.
    The old T'nB is unrecognizable-
    Is its chassis aluminum? It looks too "unrusty" for an iron one that age, even if zinc plated.
    Can you explain something about your sidelighted acrylic panel?
    Thanks and congratulations.
    Glasgow, Scotland
    7,251
    Received: 13/0
    22
    Thanks JM!
    The T'n'B's original chassis was steel with a greenish-yellow transparent coating. I believe this is called yellow chromate, and it was usually used on top of zinc or cadmium plating. It's a very effective way of rustproofing. I added a brass faceplate when I removed the old front panel, and when I rebuilt the amp, I made the new chassis out of 3mm aluminium plate.
    As for the panel, I used Autosketch to make a DXF file of it, and gave it to a friend at the university rapid prototyping shop. It was then cut and engraved into 3mm clear acrylic using a CO2 laser. To make sure the holes lined up, I used the same DXF to print a paper template for drilling the front panel.
    Anyway here's a link to Weber's nameplate service Weber Design
    Going to have to go back and add the attachments
ID:	8266   Click image for larger version.
ID:	8267   Click image for larger version.
  12. #12
    Oct 2007
    10,966
    Received: 1,103/15
    Given: 827/23
    25
    Pretty impressive or impressively pretty, take your pick.
    Someday all amps will/should look like this.
    Yellow chromate is the best.
    I use blue chromate on my speaker frames because "that's what Celestion uses" and my clients much prefer that , but yellow/greenish is best.
    Are those Leds side-firing?
    Big doubt: how do you manage to mount your pot nuts, considering the 3mm aluminum + 3mm acrylic?
    Or is it 3mm acrylic plus original <1mm ?
    You should post some MP3.
    The biggest doubt of all: what does the "lady of the house" say about all those little pieces of wire strewn on the floor?
    Don't bother to answer that one, I guess the answer is universal.
    I guess that gaffer tape holding a cap across the rectifier bridge is the "secret mod", isn't it?
    Of course it must come from that roll of tape sold at Sotheby's by Jimi Hendrix's ex stage assistant, for a meager $10000, guaranteed to having been used at the Isle of Wight festival in 1970.
  13. #13
    Dec 2007
    932
    12
    I also had Weber make me some nameplates. The hardest thing was deciding on a font.
  14. #14
    Supporting Member tubeswell's Avatar
    Feb 2007
    Wellington NZ
    4,145
    Blog Entries
    1
    Received: 63/0
    Given: 18/0
    18
    Smooth retro lookin' font Diablo
  15. #15
    Dec 2007
    932
    12
    That font is called "hood ornament". Looks to me like it came from a 1959 Buick.
  16. #16
    Glasgow, Scotland
    7,251
    Received: 13/0
    22
    Sweet looking guitar too! What are the pickups?
    JM: You asked about the nuts, and the front panel thickness. The first time I did this, I got bitten by that problem, and the nuts would just barely engage with the threads. Luckily the metal I used that time was only about 1.8mm.
    The Deluxe was my second edge-lit build, and I just made the holes in the acrylic so big that the nuts would go down inside them and tighten against the metal. So there was no problem even though there was 3mm of metal and 3mm of acrylic. Then I installed all the pots before putting the acrylic on.
    The LEDs are just ordinary 3mm high-brightness ones with clear cases.
    I have the usual noise problem, living in an apartment I don't get to crank it up that often. I built it back when I was gigging with a band. I may be able to bring it into the studio at work to get some recordings.
  17. #17
    Dec 2007
    932
    12
    The guitar is a 1972 Les Paul Deluxe with the stock mini-humbuckers. The pickups have the embossed "Gibson" covers. A lot of folks routed their Deluxes for full sized humbuckers, but I left well enough alone.
  1. Shared cathodes but not plates
    By lowell in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-06-2009, 11:12 PM
  2. El34's and 800V on the plates
    By Bernardduur in forum Theory & Design
    Last Post: 03-27-2009, 05:59 PM
  3. Grounding plates
    By Dr. Guitar in forum Pickup Makers
    Last Post: 05-03-2008, 10:32 AM
  4. One Tube Red Plates
    By s2amps in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-10-2007, 07:31 PM
  5. Carbon Comps On Plates And Cathodes?
    By RANDY in forum Theory & Design
    Last Post: 10-09-2006, 11:53 PM
