How many volts should be reading on power tube and preamp tube pins?
Fender twin reverb tube voltage
fender twin reverb tube voltage
I bought a 1973 fender twin on ebay the first time I stepped on the reverb pedal it made a loud squealing noise and the volume went way low and sounded distorted. I ended up replacing all tube sockets tubes caps and resistors then rewired most of the amp. After all the work was done I could not get any sound this morning I realized I did not solder the input jack correctly now it works however the vibrato and reverb are not working and plugging in the vibrato side is not as loud as the normal side I checked the bias on the tubes and they are between 29 and 32 milliamps. Some of the preamp tube plates are glowing. I'm a newbie to working on amps so I'm more or less trial and error at this point. any advice is appreciated.
Originally posted by gla1013 View PostSome of the preamp tube plates are glowing.
Here is a schematic for the non-push-pull master volume version:
http://www.schematicheaven.com/fende..._nomstrvol.pdf
And here is the push-pull MV:
http://www.schematicheaven.com/fende..._100_schem.pdfLast edited by RWood; 03-01-2010, 08:00 PM.
