I am purchasing a new function generator, and I'm wondering how I can use it to go to the input jacks on guitar amps, all i have seen is banana jacks or BNC, But i cant find a cable or adapter to feed it in, I am new at this, but its all a part of learning
BNC or Banana Jacks to 1/4 jack
I'm looking at these options
1. Has 1/4 jack on the backhttp://www.mcmelectronics.com/product/72-490
2. Has Banana Jacks ROOM EQ SINE SQUARE WAVE AUDIO TEST OSCILLATOR 4 PULTEC on eBay.ca (item 350201651273 end time 09-Mar-10 12:25:37 EST)
3.BNChttp://cgi.ebay.ca/Digital-Function-Signal-Generator-5-digit-0-2Hz-2MHz-ap_W0QQitemZ280472112391QQcmdZViewItemQQptZLH_DefaultDom ain_0?hash=item414d70cd07
which would be the best solution? and if anyone knows the cables to go with them it would be greatly appreciated
A simple approach is to buy a cheap molded guitar cord, lop one end off, and mount a dual banana male there or a BNC. In fact, you could get like an 8 foot cord, cut it in half and make both.
COmmercial test leads and adaptors are available many places, here are some items from MCM with their stock numbers:
201-006 BNC female to dual banana male adaptor
I don;t see them at MCM, but they do also make the reverse - banana females to BNC male. Both types are useful in the shop. OOps, here it is, 76-005
201-101 BNC male to minigrabber clips 36" lead Pomona
201-103 banana dual male to minigrabbers 36" lead Pomona
21-600 BNC male to minigrabber clips 36" lead Tenma
21-605 BNC male to aligator clips 36" lead Tenma
BNC and 1/4" is not a mix I usually see, but BNC/RCA is common enough, and shove a RCA female to 1/4 male adaptor on it and voila! or make it an RCA female.
For example 27-405 RCA-f/BNC-m adaptor
combined with a RCA-m to 1/4-m cord 24-675
Or a BNC-m to RCA-m cable like 33-530
Got any dead scope probes? if the BNC and cable part is OK, wire a 1/4 male on the probe end.
Darn, I had nice picture links, but they didn;t work.Last edited by Enzo; 03-03-2010, 09:25 AM.Education is what you're left with after you have forgotten what you have learned.
WHy not. it is a very basic little unit, but how fancy does a sine wave generator have to be? For me the frequency and the level have to be continuously variable. (As opposed to something like a high-medium-low switch) This unit covers that.Education is what you're left with after you have forgotten what you have learned.
BNC to RCA adaptor... RCA lead... RCA to 1/4" jack.
Or you could get a BNC lead, lop off one end and put a jack on. I like the RCA kludge because it can hook up to stereo amps too."Enzo, I see that you replied parasitic oscillations. Is that a hypothesis? Or is that your amazing metal band I should check out?"
would either of these work for banana jacks?
Amazon.com: PYLE PPSC-BN100 Banana Plug To 1/4" Speaker Cable: Electronics
or
Amazon.com: Hosa BNP-116 16 AWG 1/4" Female to Dual Banana Adapter (6-Inches): Electronics
I wasnt sure about running speaker cable into the input jack, i know its not good running guitar cable from head to cab.
Those are speaker cords, so they are not shielded. You do not want to connect an unshielded cable to the input of an amplifier - you will get lots of humEducation is what you're left with after you have forgotten what you have learned.
