Can someone tell me what kind of input jack I would need to feed a 2-channel amp, say a JTM45 with high inputs only (1 per channel) and add a 3rd input which is a mix for both in parallel? Can I do this with typical Marshall 4-lug Cliff jacks? I tried for a while today to figure this out (w/ those Cliff jacks) and I'm stumped.
2 channel input w/ mix
Originally posted by EFK View PostCan someone tell me what kind of input jack I would need to feed a 2-channel amp, say a JTM45 with high inputs only (1 per channel) and add a 3rd input which is a mix for both in parallel? Can I do this with typical Marshall 4-lug Cliff jacks? I tried for a while today to figure this out (w/ those Cliff jacks) and I'm stumped.
Are you talking about plain old uninsulated jacks? I'll have to think on that - would do away with the sleeve connection as that would just be to chassis. I've seen it done with uninsulated jacks. The reason I was trying to use these Cliff jacks is I want it all insulated from chassis; I was trying to mount the 1M resistors for each input on the jack as well.I had it all figured out from the hot side, unfortunately I couldn't come up with a 'switching' ground system and my ground kept bleeding back into my inputs. That probably doesn't make sense.
Originally posted by beefwhiff View PostWith the above config., the top jack is useless. It does the same thing as the middle jack. Plugging into the bottom will only give U1. Middle jack = U1 + U2. Top jack = U1 + U2. Or am I missing something stupidly obvious?
