bout the weight of transform
  • bout the weight of transform
    present, many brand amps use samller transform in their amp.even peavey and vox.
    This is reduced the manufacture cost. But we known that the inductance , the diameter of Cu wire of transform are important . The size of core effect inductance. The larger the core is, the larger the inductance is.The thick the diameter is, the current passed through is. Certainly larger core and thick coil will make transform larger. But they make sound better.
    Thats what i'm hoping, because i just got my magnetic components "classic tone" set today, and the PT has got to weigh 20 Lbs if it's an ounce !
