What happens if I just leave out the death cap, rather than replacing it with the standard 18/3 power cord setup?
5E1/5F1 Death Cap
It's a hypothetical. I realize it's way easier to just install 3 wire, but am curious as to what it would actually do to the circuit.
seeing as to how you replied to my other thread... I got the chassis all put together and had to go to work, meanwhile at work, I realized I had left out that cap. Would that cause my problems?
The chassis would not be gnd referenced. The output will be noisy and you run a big risk of getting blasted from the floating chassis when you touch something at proper gnd while touching any metal part on the gtr/amp.The farmer takes a wife, the barber takes a pole....
