Gregory Reverb 1500?
  • Gregory Reverb 1500?
    Anyone ever seen a schematic for a Gregory Reverb 1500?
    A customer wants me to repair his, and there's a voltage dropping resistor between two lugs of the power supply cap that's heat-damaged to the point where you can't read its value. It also has one transistor in the reverb circuit that no longer has any identifying marks on it.
    Thanks!
    David
    Here's a hand-drawn circuit of the preamp/driver and reverb driver circuits of the Gregory Reverb 1500.
    I've never seen an guitar amp input circuit quite like this--in terms of the number of components before the first gain stage.
    And note that the reverb pot is the cathode resistor for the first 12AX7 section.
    David
