Looking for schem for the above. anyone help?
Behringer Ultrabass BX4500H wanted
Can't provide a schematic, but what are you fixing? In my experience, you either have a blown output in the powr amp or a bad op amp in the preamp. Close? Usually can find a bad op amp by going down the row and reading for DC voltage at each output pin.Education is what you're left with after you have forgotten what you have learned.
BX4500 pre, BX1200, BX1800, Ep2500 amp
the amp may be close to what you have.
i hope the files help someone
Dont give up yet. Even without the schematic many amps have been fixed with help from the very kind people who inhabit this forum.
Step 1. Check all output transistors & their ballast resistors for shorts.
Step 2. Measure power supplies, are they all ok, this includes the power supplies to the op amps.
Step 3. Is there DC on the speaker output ? Do not connect a speaker for any testing yet
Step 4. Plug a patch lead into the send & return jacks, does this help
Step 5. Plug a patch lead into peeamp out / power amp in (if these are on the amp), does this help
Step 6. Are you getting signal out of the preamp ? Hint, as Enzo said above, check the output pins of each op amp, are any sitting close to the supply rails or are thay all close to 0V
read post #2 again. and before we go into anything else, what is the actual problem with the amp ?
do you get no sound, or a very distorted sound, has it been over heated, or had drinks spilt through it ?
If you give us specific complaints or problems, we can probably give specific advice.
I have the schematic to look at, I am just forbidden to post it. I can answer questions about it and discuss it though.Education is what you're left with after you have forgotten what you have learned.
The the speaker output goes hard over to one rail. The problem seems to be there seems to be no centre tap to the high power winding on the transformer, so cannot figure out how the voltage rails are maintained equally about 0vI am a very humble person. I am far better than I think I am
Hi JM.
As you rightly comment, the transistor collectors got to 0v (wherever that is) and the centrepoint of the main caps go to the speaker 'hot' terminal.
All the main transistors check out ok.I am a very humble person. I am far better than I think I am
