Page 1 of 2 12 LastLast
Results 1 to 35 of 52
Thread: New 5e3 build, faint sound..
    Member 01bcat's Avatar
    Apr 2010
    Midwest USA
    31
    0
    Hello everyone, new member, just finished my 1st build (newbie to this) and I can hear only a very faint signal through the speaker, volume has to be cranked.
    Tubes light up fine. Any suggestions on what to look for?
    Here is a link to the layout.
    http://site.triodestore.com/5E3Delux...-18021120V.pdf
    Bent Member Chuck H's Avatar
    May 2007
    pacific north west
    14,971
    Received: 2,018/4
    Given: 2,299/0
    29
    The fault could be almost anywhere. Along your signal path, In the voltage supply, mistake in the grounding, etc. A signal trace and voltage check will probably locate the problem. Since your new at this it's most likely a simple little miswire somewhere It's the same formula for everyones first couple of builds... Build amp, track down errors, then tweak.
    Chuck
    Apr 2010
    Midwest USA
    31
    0
    Thanks Chuck, I have gone over it a few times - can't seem to find a wiring error. Is there any info out there will tell me what the voltages should be, and where to check?
    Senior Hollow State Tech Bruce / Mission Amps's Avatar
    Denver, Colorado
    3,045
    Received: 7/0
    17
    Quote Originally Posted by 01bcat View Post
    If Triode has ever built one of their own kits, they should be the ones you're asking for that info.
    I can't imagine them not having that info right at hand or not being able to help with it.
    Why don't you tell us what the voltages are on your amp and something might jump put.
    Bruce
    Mission Amps
    Denver, CO. 80022
    www.missionamps.com
    303-955-2412
    Apr 2010
    Midwest USA
    31
    0
    Hey Bruce,
    I chose the triode kit because they are a few suburbs away, picked it up the same day ordered. They give you a layout, that is it.
    I will check voltages and post them. Any common newbie mistakes that I can look for?
    Nov 2007
    32
    0
    01bcat,
    I built a Triode kit a year ago. My first build also.
    Am very satisfied with it. It's been used more or less daily
    No problems at all.
    There are several schematics on the net with voltages
    for the 5E3. Google will find them for you.
    Google fender 57 Deluxe schematic
    ...and you'll find link to a schematic with voltages near the top.
    I used the Triode layout and the Fender layout for reference when I built mine.
    FWIW, the Triode print is correct... enough.
    (I changed the grounding on mine for quieter operation)
    I was very careful, double-checking and triple-checking everything as I
    built the amp and still made a couple of dumb wiring mistakes.
    Lucky I didn't let the smoke out of something.
    Beginners luck I guess.
    I had the output jacks mis-wired. The symptom was very similar
    to what you described. I'd mixed up the external and output jacks.
    In my case, plugging into the external jack gave me normal operation.
    Just corrected the wiring problem and have had no problems since.
    One thing I did find was that since the PT is wound for the old 110Vac
    of the 50's, voltages were a little high.
    For my 120vac wall outlets R.G. Keen's Vintage AC solution
    gave me pretty much the same voltages as the Fender schematic
    on the Fender site.
    Hope this helps
    Apr 2010
    Midwest USA
    31
    0
    Zephyr,
    Nothing wrong with the kit, and getting it the same day was really cool. Saved on shipping as well. Looks like quality stuff. A way to mount the board, and grommets for the transformer wiring would have been nice though. Spent a bunch of time at the local hardware store.
    Thanks for the info on the voltages, I will check it out.
    Did you choose the Mallory caps?
    Mar 2010
    La Mesa, CA
    73
    10
    I just finished my first build. I am no expert, but mine had a similar problem. Things all seemed fine, but very low volume. I finally found I had somehow placed a 100 ohm instead of 1 meg resistor on the input jack. I guess I was bleeding the input signal to ground.
    Apr 2010
    Midwest USA
    31
    0
    Thanks gsr, I will recheck all my resistor values..
    Denver, Colorado
    3,045
    Received: 7/0
    17
    Another common error is to swap the 100 ohm filament balance/ground reference resistors with one or more of the 100K resistors on the plates of the preamp tubes.
    Bruce
    Mission Amps
    Denver, CO. 80022
    www.missionamps.com
    303-955-2412
    Apr 2010
    Midwest USA
    31
    0
    Hey Everyone,
    I appreciate all the advice.
    Just rechecked the entire circuit, including resistance values. Could not find an error. While I know the larger caps have a polarity - do the mallory 150s?
  12. #12
    Dec 2008
    Wernersville, PA
    12,827
    Received: 449/2
    Given: 236/0
    25
    5E3
    Check every preamp pin #1 & pin #3. Pin #6 & #8.
    Plate & cathode .
    Measure it at the pin.
    The 6V6 tubes check pin #3 & #8.
    Plate & cathode.
    Please advise what you come up with.
    This a just a routine static amp check to see if the amp is functioning.
    If all appears well, a signal test is next.
  13. #13
    Apr 2010
    Midwest USA
    31
    0
    Will get to it tomorrow Jazz, thanks.
  14. #14
    Apr 2010
    Midwest USA
    31
    0
    Hey Everyone,
    OK- Here are the numbers:
    12ay7
    1-120 2-0 3-0 4-0 5-115 6-0 7-2 8-0
    12ax7
    1-150 2-0 3-1 4-0 5-0 6-114 7-0 8-0
    6v6
    1-0 2-0 3-395 4-360 5-0 6-0 7-0 8-23
    6v6
    1-0 2-0 3-393 4-358 5-0 6-0 7-0 8-24
    5y3
    1-0 2-404 3-0 4-368 5-0 6-370 7-0 8-404
    Any advice is appreciated!
  15. #15
    Dec 2008
    Wernersville, PA
    12,827
    Received: 449/2
    Given: 236/0
    25
    Heater Voltage
    I do not see correct heater voltages.
    The 12AY7 pin 5 at 115 volts is not good.
  16. #16
    Junior Member
    May 2009
    9
    0
    Quote Originally Posted by Bruce / Mission Amps View Post
    I did that and you caught it from looking at the pictures I sent!
    When I fired the amp up for the first time, all the tubes lit up but no sound. There is a shielded wire from the volume pot to a preamp tube. I did not trim the shield good enough and one tiny wire was touching a lug on the tube socket. After I fixed that, glorious sound!
    Don't know if the Triode kit has the shielded wire, but if it does, check it.
  17. #17
    Apr 2010
    Midwest USA
    31
    0
    Jazz,
    I should have worn both pairs of glasses! - operator problem.
    Try Again:
    12ay7
    1-120 2-0 3-2 4-3ac 5-3ac 6-115 7-0 8-2 9-3ac
    12ax7
    1-150 2-0 3- 1 4 3ac 5-3ac 6-114 7-0 (am radio though) 8-0 9-3ac
    The 6v6 heater elements check out too.
    thanks!
  18. #18
    Apr 2010
    Midwest USA
    31
    0
    No sheilded, cloth pushback wire. Thanks though.
  19. #19
    Apr 2010
    Midwest USA
    31
    0
    Hey Jazz,
    Operator problem, added another pair of glasses...
    12ay7:
    12ax7:
    1-150 2-0 3-1 4-3ac 5-3ac 6-114 7-0(with am radio) 8-0 9-3ac
    The heater elements check out on the 6v6's as well (the other info on them should be accurate)
    Thanks!
  20. #20
    Denver, Colorado
    3,045
    Received: 7/0
    17
    Hey Jazz,
    12ay7:
    12ax7:
    Thanks!
    Filaments are fine.
    Radio on lug 7 is bad...
    Check lug 8 of the 12AX7 with respect to ground... it should be at least 35vdc to 60vdc in order for the tube to even turn on.
    I suspect an error there... maybe too many glasses now though.
    Bruce
    Mission Amps
    Denver, CO. 80022
    www.missionamps.com
    303-955-2412
  21. #21
    Apr 2010
    Midwest USA
    31
    0
    Hey Bruce,
    I can't help the eyes much - but I will check it out - thanks...
  22. #22
    Apr 2010
    Midwest USA
    31
    0
    O voltage on pin 8, also none across the cap it is connected to... ?????
  23. #23
    Apr 2010
    Midwest USA
    31
    0
    Its Alive!
    Thanks for the help, I missed a connection under the board.
    It is humming like crazy, but the tone is there, just need to clean up the wiring, maybe change some grounding as Zephyr suggested.
    Zephyr- can you tell me the changes you made to the grounding?
    Bruce, your comment led me right to it.. Thanks.
  24. #24
    May 2007
    pacific north west
    14,971
    Received: 2,018/4
    Given: 2,299/0
    29
    The hum could be another wiring error. Miswired grounds can hum but a bad hum is usually indicative of a bigger problem like a miswire or a cold solder joint.
    Chuck
  25. #25
    Apr 2010
    Midwest USA
    31
    0
    Chuck,
    I am going to go over everything once more, an re-do the heater wiring.
    My volume goes from nothing the really loud in like 1/100s of a turn, if I dime it (or $0.12 it in this case) it squeals.
    Any suggestions on where to look for the cause there?
  26. #26
    Sep 2009
    state that looks like a mitten
    83
    10
    a volume pot lead contact to ground (due to rotation and not much room) will cause problems too
    don't ask how I know this
  27. #27
    Denver, Colorado
    3,045
    Received: 7/0
    17
    It also sounds like an input jack could be wired wrong and or not grounded right.
    Short lugs 2 and 7 of the first preamp tube right to ground with an alligator clip lead and see if that kills the noise.
    Bruce
    Mission Amps
    Denver, CO. 80022
    www.missionamps.com
    303-955-2412
  28. #28
    Apr 2010
    Midwest USA
    31
    0
    Thanks, I will do that. There is NO clean headroom either.
  29. #29
    Apr 2010
    Midwest USA
    31
    0
    OK - Stupid question:
    If I touch the leads dropping to the 68k resistors on the normal input jacks, it shows continuity with ground. The brite jack leads do not. Normal?
    Thanks.
  30. #30
    Denver, Colorado
    3,045
    Received: 7/0
    17
    No... the switching jacks should have the two resistors grounded at the input jack end.
    I think that point should read about 32K-36K range on both pairs of resistors with nothing plugged into the jacks.
    Bruce
    Mission Amps
    Denver, CO. 80022
    www.missionamps.com
    303-955-2412
  31. #31
    Apr 2010
    Midwest USA
    31
    0
    I was checking the resistors, that is how I caught it, switch on 1 jack wasn't working.
    I also tried grounding the tube pins, no help. Still distorted, volume jumps in one spot on the knobs. Sounds terrible.
    What next? Could it be a bad OT?
  32. #32
    New Member
    Jan 2010
    4
    0
    Bruce,
    I just completed a first-build 5E3 myself, which I believe is a little noisy. If I short lugs 2 and 7 of V1 to ground as you described, what specifically should I look for in my jack wiring, presuming that does stop the noise...
  33. #33
    Apr 2010
    Midwest USA
    31
    0
    Raspy tones.....
    I completely rewired my heaters and it substantially reduced the hum.
    But I have absolutely no clean headroom at all, and when it does break up, it sounds like a blown speaker. Very little volume until 2 then it is just raspy sounding. No good tones at all.
    I rechecked the pot wiring, and the input wiring, and re-flowed the joints.
    Does anyone have any ideas what it could be, or have you had similar problems?
    Thanks.
  34. #34
    Denver, Colorado
    3,045
    Received: 7/0
    17
    Quote Originally Posted by Phildaman View Post
    Bruce,
    Is it one of my kits and if so did you download the 110 megabyte photo album builder guide work?
    I'd review the input jack's lugs vs the 1M resistors and the middle switch lug to be sure they are correct.
    With no 1/4" phone plug inserted into any of the jack, the two grids of the preamp tube are at very very low potential and should be very quiet unless the preamp tube is bad.
    Bruce
    Mission Amps
    Denver, CO. 80022
    www.missionamps.com
    303-955-2412
  35. #35
    Denver, Colorado
    3,045
    Received: 7/0
    17
    Thanks.
    I have to assume you've double checked all your wiring but triple check to see if you have the wires from lugs 7 and 8 going to the right resistors on the circuit board... they could be flipped around on the 12AX7 socket, the one closest to the speaker jacks.
    Bruce
    Mission Amps
    Denver, CO. 80022
    www.missionamps.com
    303-955-2412
  1. 5e3 Clean Sound
    By BluesDude in forum Tweed Builders
    Last Post: 01-27-2010, 04:32 PM
  2. faint signal at zero volume
    By jreese2001 in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-20-2010, 09:25 PM
  3. faint hum from 9V Boss switching adapter
    By Guitarist in forum Guitar Effects
    Last Post: 06-17-2009, 01:46 PM
  4. fender faint sound
    By ppxstnr in forum Maintenance, Troubleshooting & Repair
    Last Post: 11-19-2008, 10:41 PM
  5. Jcm 800 build not giving any sound
    By Realeigo in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-20-2007, 03:22 PM
