Hi, I have two speakers I want to put in a 2x12 cab. They are the same ohms but different wattage. Will wire in parallel. What will happen?
mix & match?
They will share power equally. If you increase power to them enough, eventually, you will reach the limit of the lower power one and it will fail.
In other words, if you have a 20w and a 100w speaker in parallel, you can apply up to 40 watts to the pair - 20 watts per speaker. If you apply 100 watts to the pair, each will see 50 watts. The 20w one will burn up, but the 100w one will be happy.Education is what you're left with after you have forgotten what you have learned.
