Mackie SRM450v2
  • Mackie SRM450v2
    Anybody have the schematics for the Mackie SRM450v2?
    Need to convert from 110v --> 240v -- is it really as simple as cutting the one wire and replacing the fuse?
    Cheers,
    matt.
    It uses a switching power supply, so yes, it may be that simple. There may also be some minor changes to the mains section. COntact Loud Technologies for the drawings and conversion information.
      I hope that the power supply schematic will help you.
        Hi, I have the same problem, need to convert from 110v to 240v, I contacted Loud Technologies, they were not very helpful. Did you have any luck converting them? thanks, magne
          I am Trying to do the same thing but in reverse. (240-120) it looks like I should be able to simply bridge a couple points and change the fuse.. How successful were you gents with the 240 to 120 conversion?
