Using hifi-amp
  • Using hifi-amp
    Hi, this is my first thread in ampage.
    I have an stereo tube amp, which was removed from
    an old reel deck. It uses an 12AX7 and two EL84s.
    I would like to make this use of guitar practice amp with
    my digitech rp80.
    1. However, I heard that tube amp can be broken
    without connecting speaker. To keep it from
    being broken, should I pull out one of EL84s?
    2. I don't have any extra spearker, so I think I should
    pull out tube of one channel. However, I heard that
    to pull out tube(s) can cause to increase B+ overall
    and kill all parts (soon or later). Is it right?
    To make story short, should I modify its PSU in order to
    lower the B+?
    Thanks.
    use RP80, However, it has only one channel.
    I would like to put my digitech digital
    gear (RP80) into it.
    I don't understand what you are using this for if it's not connected to a speaker, however I believe you are right about needing a speaker and raising the B+ voltage. Whether or not this will damage the rest of the amp is hard to say, it may , or your amp may be able to handle the increased voltages.
      Pull the tube, measure the B+ Tubes can take a fair amount of voltage.
      Those tubes, in class A, are only a few watts
