Hi, as a radio technician from the 60's I am trying to fix the amp. The issue i have is that the two valves are 6L6GCR made in China, and I am having a problem with the bias setting - 8A-10C board. The chassis is 2100-B-AX. Would appreciate comments. Thanks, Peter.
Music Man 100-B Bass Amplifier
Originally posted by Peter March View PostHi, as a radio technician from the 60's I am trying to fix the amp. The issue i have is that the two valves are 6L6GCR made in China, and I am having a problem with the bias setting - 8A-10C board. The chassis is 2100-B-AX. Would appreciate comments. Thanks, Peter.
Topics - Music Man Amps Discussion Forum
What's the problem?
I've worked on a lot of MM stuff, but don't recall this particular one, is this the tube driver or is it the solid state cathode driven version?
It is the solid state cathode driven one, on the 2100-B circuit board. With just the one adjustment compared to two in the Fender models - bias and balance between the two in that brand - there is only the one adjustment here. Therefore with only one measurement across the 3.9 ohm resistors for what I understand is 25 mV to be set, what happens if the other 3.9 ohm resistor has a higher or lower voltage across - what is the preferred maximum and minimum voltages between them that the set up has to keep them?
Cheers,
Peter
Originally posted by Peter March View PostIt is the solid state cathode driven one, on the 2100-B circuit board. With just the one adjustment compared to two in the Fender models - bias and balance between the two in that brand - there is only the one adjustment here. Therefore with only one measurement across the 3.9 ohm resistors for what I understand is 25 mV to be set, what happens if the other 3.9 ohm resistor has a higher or lower voltage across - what is the preferred maximum and minimum voltages between them that the set up has to keep them?
Cheers,
Peter
