Page 1 of 2 12 LastLast
Results 1 to 35 of 63
Thread: Phaez gives away EL84 design
    Old Timer tedmich's Avatar
    Apr 2008
    Sonoma CA
    3,239
    Received: 124/0
    Given: 60/2
    14
    Phaez amps guy Randy Fay (ontariomaximus on youtube) has kindly made his EL84PP design available over at AX84. Its quite simple and has a wonderful tone.
    clips
    YouTube - Phaez Daisycutter 14 watt with EL84's
    discussion
    AX84.com - The Cooperative Tube Guitar Amp Project
    schematic
    http://tubeampmods.com/18w_daisycutter_april_2010.jpg
    Senior Hollow State Tech Bruce / Mission Amps's Avatar
    Denver, Colorado
    3,045
    Received: 7/0
    16
    Sounds like a moderate dose of reverb and digital delay mixed in there too.
    Ho hum... just what we need, another wanky, over driven El84 amp... but I guess that's what the AX84 site is all about anyhow, so... have fun children.
    1 Not allowed! Not allowed!
    Bruce
    Mission Amps
    Denver, CO. 80022
    www.missionamps.com
    303-955-2412
    Mar 2009
    519
    Received: 22/0
    Given: 25/0
    11
    Bruce burn. Ouch.
    Apr 2008
    Sonoma CA
    3,239
    Received: 124/0
    Given: 60/2
    14
    Quote Originally Posted by Bruce / Mission Amps View Post
    its two amps with a delay to the second one I believe, as Randy states he likes that sound and dislikes FX loops.
    AX84 is about collaboration and community and many very smart people enjoy it, hardly children.
    It may not be what YOU need Bruce, but that's been open to much conjecture over the years, usually involving something with a relatively high velocity
    Jan 2008
    Montreal, Canada
    219
    12
    So basically, he wanted to add a tone stack to the Tiny Terror, so he switched to a (pardon me here but I don't know the exact name for that one-triode PI) and used the extra triode to drive the tone stack.
    I'm not sure why he's driving it with the anode though, I'm guessing max gain was the point here.
    A high-gain 2XEL84 is actually something that a lot of rock guitarists are asking for at the moment. Even Marshall came out with the Haze15 (6V6 actually) which is... really not that good, but it shows what people are asking for.
    It's true though that in practice, especially with a band, high-gain does not always go so well with low-power.
    Jun 2006
    275
    Received: 5/0
    Given: 2/0
    13
    I think the use of a concertina directly after the tonestack is rather clever. The concertina has a gain of (slightly below) 1, so whatever signal level comes out of the tonestack is what has to drive the power tubes. It works with EL84s, but probably not with bigger tubes.
    484
    13
    Quote Originally Posted by d95err View Post
    Many old EL34 amps use a cathodyne/concertina PI. The Dynacord Eminent EMT comes to mind.
    Beam power tubes like 6L6 need more voltage swing, so an LTP would be a better solution.
    Cheers,
    Albert
    Jun 2006
    275
    Received: 5/0
    Given: 2/0
    13
    Quote Originally Posted by Albert Kreuzer View Post
    Cheers,
    Albert
    The concertina is typically preceded by a gain ("driver") stage to get maximum output through the PI. The clever part of this design is skipping the driver stage, despite the tone stack dropping the signal level significantly.
    It works here because EL84s don't require very high signal levels to drive, and because it's a high-gain design that doesn't need to smash the output stage with insane signal levels to get distortion.
    Apr 2008
    Sonoma CA
    3,239
    Received: 124/0
    Given: 60/2
    14
    someone at ax84 postulated the varied bias points on the pre gain stages creates "harmonic complexity"
    I don't know, but it breathes beautifully IMO
    Jan 2008
    Montreal, Canada
    219
    12
    Quote Originally Posted by tedmich View Post
    Most high-gainers (if not all) have varied bias points.
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    11,119
    Received: 1,283/18
    Given: 979/24
    26
    Thanks for posting.
    Probably not a ground breaking design, but has the interesting trick of having the Master volume *just* before a gain-of-one PI, which turns it into the functional equivalent of a PPI Master Volume.
    I think it's a little overpowered for a bedroom-warrior musician, the classic 5 watts typical of AX84 being better suited to the task, and it definitely is underpowered for stage use.
    Yea, I know that driving 4 x 103dB/W Fanes in an old Hiwatt cabinet or 2 15" JBLs in a Dual Showman cabinet it will be deafening, but the real world commercial speaker within its builder's budget will not be that loud.
    As a side note, I like different AX84 versions very much.
  12. #12
    Denver, Colorado
    3,045
    Received: 7/0
    16
    That was tongue in cheek but...
    Right, not only do I not need them, I hate the juvenile sounds of massive preamp overdrive and thin over driven EL84s... Bumble bees in a paper bag... wanker stuff.
    To be honest, I guess a guy should give the end user what ever they think they want, it's their money.... but I don't know anyone who actually plays out, (even once in blue moon, semi-professionally), that uses those kind of amps.
    I do know know lots of kids and youngsters who try to use them and I hear them furiously wanking away like mad every time I stop by the local Guitar Center to visit some friends, then I run to the restroom and vomit.... with the other adults.
    And by the way, it's just a hobby but I've known and supported Chris at AX84 for many years... so I am quite aware of what turns the crank and squirts the grease there.
    At least the Ark Amps are cool looking!
    Bruce
    Mission Amps
    Denver, CO. 80022
    www.missionamps.com
    303-955-2412
  13. #13
    Bent Member Chuck H's Avatar
    May 2007
    pacific north west
    14,556
    Received: 1,563/4
    Given: 1,726/0
    28
    Hey... Wait a moment. I gathered the toungue in cheek, but I didn't think you really had such disdain for the late model run of OD EL84 amps on the scene. I'm thinking about the Tiny Terror, the Badger, the Dr. Z offerings, The Vox reissues and of course the Trainwreck Liverpool clones. The Marshall "18 Watt" thing is a crossover distortion, over done buzzy mess, but there are some viable options using this power tube. My 2009 NAMM show offering for Dean Markley was in this genre and I think it's a really good amp.
    The OD EL84 thing is really "last week" in the amp biz though. My design was actually shelved in favor of a 6L6 Chinese labor MV model cheapo...
    With the economy in the tank the market has become very specific. Bad scene for some of us. (I don't have to tell you)
    Still. don't lump us all in together with the "18 Watt" clones. Some of us designing with EL84"s ARE trying to make good amps.
    Chuck
  14. #14
    Oct 2007
    11,119
    Received: 1,283/18
    Given: 979/24
    26
    Well, you don't have to tell me, neither.
    Only thing that saves me, in Argentina, is that our drummers play LOUD, and 18 watters just don't cut it, so kids (95% market share) do consider getting a local made 50 or 100 watter instead of a "famous label" Tiny Terror, Night Train, Haze, or whatever, and those who don't, get swamped by a much louder friend at the next session. God bless loud drummers.
    As a side note, I also get to sell a lot of 2x12" SS100W powered guitar boxes, to boost those who bought an underpowered tube amp.
  15. #15
    Aug 2006
    Lancashire
    649
    Received: 15/0
    13
    At the risk of you giving EL84s a bad name, they don't have to sound any thinner than EL34s. Both have extremely similar grid current characteristics. The 'traditional' thinness is mainly due to OT choice; EL34s typically use lower primary impedance.
  16. #16
    Denver, Colorado
    3,045
    Received: 7/0
    16
    Flame away
    Quote Originally Posted by Merlinb View Post
    Well, here I mostly agree. A classic AC15 or AC30 comes to mind.
    The trend with most new El84 amps (yes of course there are great sounding ones too)... is that thin, leaning into shrill, over driven sound... but I think how they are overdriven is 90% too much preamp gain with bass cut so the PA is not flubbed out.
    I don't know about the OT zed being the culprit though.
    Most of the push pull EL84 amps I see are using 7500-8500 ohm OTs with their speaker loads. The best sounding EL34 amps seem to be around 3200-3400 ohms.
    Regardless, that is the juvenile sound I am referring to and I can't name one single PP EL34 amp that sounds like a 3-18 watt El84 amp buzz bomb.
    The buzzy, bumble bee in a paper bag tone taste of many younger players are the reason for this god awful tone, not the tubes.
    Probably it's just a generational thing and nobody has to man up and agree with me.
    Pour on more clipped preamp gain or add a stomp box.
    I don't think many of those players even need a tube amp to be honest.
    It's all pimple faced geek 90cc chain saw tone at that point.
    I think my main point was that the hard core, low-mid wattage, over driven EL84s, gain monster amp crowd are not really using these things playing out live much.... unless they are allowed to krang or solo non stop through every song and have the tone set to icepick treble shrill levels, they'll get handed their shorts in a stage setting... otherwise it will be fuzz mud.
    I host an open night at a very popular club here in Denver, two to three times a month and I get to hear a lot of players and a lot of amps... some even custom made.
    90% of the players using the 12-18 watt OD 84 amps are amateurs or relatively new builders or players at best. (I don't really care for the way the Fender EL84 amps sound either... like a Blues Jr... another semi beginner guitar players amp)
    What's funny is that some players bring in these toy amps and 5 device pedal board too... their tone is utter crap by that time.
    It has been my experience that even the loudest 12-18w OD EL84 bedroom amps don't really cut it once they are brought up to stage volume.
    But if a player is a bedroom warrior... more power to them, at least they are playing, probably having a lot of fun and exercising their hobby.
    Bruce
    Mission Amps
    Denver, CO. 80022
    www.missionamps.com
    303-955-2412
  17. #17
    Mar 2009
    519
    Received: 22/0
    Given: 25/0
    11
    I just played a show last night where two younger guitar players were both playing Tiny Terrors through typical Marshall 4x12s. They could not keep up with the drummer at all, and had to turn all the way up. It was everything Bruce was describing tonally and more (or less). One guy told me he was going to get another 2x12 to make it louder...I didn't even know how to respond! He said a guy at the store was explaining to him how '15 watts is loud enough'. Its not for a rock band unless your drummer hits like a toddler, and it was evident last night. When we played with our 100 watt 2203s, I think they could tell the difference. People who don't play live a lot in all different sorts of venues don't realize how crucial it is to have headroom on tap. I love AX84, but I need power!
  18. #18
    May 2007
    pacific north west
    14,556
    Received: 1,563/4
    Given: 1,726/0
    28
    Bruce & Gaz
    +1 on the need for watts on stage (though I would dare to say that Bruce has himself in a corner on that point with his specialty ).
    On my 'pair of EL84's' amp there isn't much preamp clipping and The Vp is about 355. This gets them just loud enough without losing their character entirely. I also chose very efficient speakers for these amps. Of course the highish Vp and efficient speaker are there to give the amp some balls on stage. Even so, stage volume clean tone?.. Forget it. The best you can hope for is clean-ish. But the OD is good for stage and isn't thin/buzzy at all. These amps are designed for tone shaping with the guitars volume knob. So the manual directs players to the speaker driven line out. Plug the line out into an A/B box and then into one of the PA mixer channels. TA DAAAA, volume boost for when you turn your guitar down. Yes it's a bit of a PITA but when I designed this amp 2xEL84's were "it". And FWIW the last one I built was a custom 4XEL84 job, so it seems the trend is losing in favor more useful wattages.
    None of this is to say that I'm not a cheesey string wanker (I did come up playing in the 80's, it was unavoidable). But that's not all I am
    Chuck
  19. #19
    Senior Member Wombaticus's Avatar
    Apr 2010
    Richmond, VA
    314
    10
    Wow, how incredibly patronizing and dismissive. There's plenty of substantive discussion there about amp circuits of all sorts, not just the subset of AX84 projects that happen to use EL84s. Why, there's not infrequently even discussion of a certain famous early Fender circuit that, despite its cult following, is so poorly designed that it looks like it was slapped together by a troop of drunken monkeys....
  20. #20
    Apr 2008
    Sonoma CA
    3,239
    Received: 124/0
    Given: 60/2
    14
    Bruce, Buzzbombs of all types and wattages are undoubtedly popular, witness the PV 5150, Carvin V3 (El34s too) etc.
    More watts push more air and thus have greater bass potential but el84s can give round sweet tones. Some guy on Youtube ran his PV Bravo (~410v B+) through a Mesa Thiele and it sounds great; the speaker was holding it back.
    Granted if you move to a concert setting you may need to "amp up" and discover the origins of the term "heavy metal" but a good bedroom amp + decent PA can minimize the "drummer dwarfed guitarist" affect.
    El84s can sound very different in different amps. The old Stromberg ASR333/ASR433s are revered for their bass response, of all things.
    http://www.audiophool.cjb.net/Schem_A/Strom_ASR-333.gif
    Check Stuart Yaniger's RLD design with its funny LED bias:
    SYclotron Audio The Red Light District
    Blame the preamp for the buzz!
    Merlin, are you suggesting lower OT impedance would help the El84 amp designs? I though that would push the output tubes harder and EL84s already work very hard... I am confused.
  21. #21
    Noodle of Reality Steve Conner's Avatar
    Glasgow, Scotland
    7,251
    Received: 13/0
    22
    Oh come on, Bruce is a grizzled old bluesman. Let him have his daily grumble. That's what the blues is about: a man, a woman, a broken home, and a tweed Fender that sounds like it's broken.
    Wombaticus, are you an AX84 member who joined to defend AX84 here?
  22. #22
    Denver, Colorado
    3,045
    Received: 7/0
    16
    Quote Originally Posted by Steve Conner View Post
    Ha ha ha ... Steve always knows me... I've been wondering how long that would take.
    Bruce
    Mission Amps
    Denver, CO. 80022
    www.missionamps.com
    303-955-2412
  23. #23
    Apr 2010
    Richmond, VA
    314
    10
    I've been lurking here for quite awhile, and as it happens, I signed up for these forums about 9 days before Bruce's comment. So no, I didn't sign up for the express purpose of defending AX84. But -- if anyone cares -- I do post there frequently there under my real name, Paul Fawcett.
    Grumpy old bluesman notwithstanding, it's a bit of a bummer finding out that the kind folks that taught me literally everything I know about designing and building amps are being spoken of dismissively by one of the legends of the business.
    For what it's worth, my current project is a side-by-side build of a straight 5E3 and my own "tweed inspired" design.
  24. #24
    May 2007
    pacific north west
    14,556
    Received: 1,563/4
    Given: 1,726/0
    28
    Bruce has never been a fan of "monkey tone". And he's never kept it a secret either. Some of the banter here is guys who already know each other (for many years in some cases) just spouting off like they're sitting down to a beer. You should lurk longer and get a feel for the community you walked into before passing judgment on one of it's own. Right or wrong.
    That said... Welcome to the forum. Remember your a pup here and treat the old timers (some of them older than others... like Bruce) the same way you would treat your parents friends. In other words, don't question them on etiquette and don't be disrespectful if you choose to disagree. That is, until you've been here long enough and are regarded for contributing information as a poster. Then we're all fair game. Some of us have been with the forum well over a decade (you can't go by the "join date", most of us have had to re-join a couple of times due to format changes) we behave however we want as if we own the place. We don't, but we like to pretend that we do. And nothing a noob with three posts has to say is going to stop us It's just "good ol' boy" comradery. You don't just walk up to a table of guys playing pool at the bar and spout off with "Hey, you guy's swear too much and second hand smoke kills." Well, not if you want to play pool anyway.
    Just giving you heat. Grow a good thick skin bro. Dealing with us is worth it. I think you'll find in time that there is more good info and more experienced assistance to be had here than any other forum of it's type. Case in point, most of us here still think of AX84 as "that new forum"... He he. Ampage is the oldest and best forum of it's kind. But as such there are dark things that lurk in the corners
    Chuck
  25. #25
    Glasgow, Scotland
    7,251
    Received: 13/0
    22
    Well, it's a matter of taste really. Bruce just doesn't like the new hard rock and metal tones, and that's fair enough. AX84 are maybe a younger community who like a bit of shredding.
    I was a teenager in the 90s, and I loved 90s metal, which in hindsight was something of an all-time low in guitar tone. But as I got older, I started to appreciate the more classic tones. Clapton on the Beano album, and the other day I was listening to Humble Pie Rockin' The Fillmore, which I'd have hated 15 years ago.
    My tastes also changed as a result of playing in bands. Less gain, more midrange, seems to get the job done better. I think even the shred guys probably don't use as much gain as you'd think when they play live.
    An 18 watt amp would be pretty much inaudible over one drummer I had the misfortune to jam with. He could make my ears ring even if I wore earplugs.
    But I know people make good use of the little 18 watt amps like the Fender Pro Jr. all the time. If it's not loud enough they just mic it.
  26. #26
    Denver, Colorado
    3,045
    Received: 7/0
    16
    Ah come on you guys... you all know I'm just being irritating on purpose.
    Most of you already know my opinion of that buzzy tone and most OD EL84 amps are the worse offenders of it. That's just he way it is.
    However, I play regularly in a Chicago style blues band with a guitar player who uses and loves his Blues jr.
    But I lovingly stick it to him all the time about his whinny El84 "blues amp"... and it's not even stock, nobody's amps are stock in any band I'm in. ... but its still an EL84 amp that is not a VOX...
    And Steve.... ahem... I was a teenager in the late 60s
    (ouch, you would bring that up) and grew up musically on the bluesy R&B streets of Detroit ... Motown.
    Oh yeah.
    I guess I'll get off my crazy horse for while now.
    Oops...
    And welcome Paul.... jump in and get to know a few of us so you can read between the lines and not feel insulted by our knuckleheaded banter.
    Bruce
    Mission Amps
    Denver, CO. 80022
    www.missionamps.com
    303-955-2412
  27. #27
    Senior Member hasserl's Avatar
    988
    Received: 1/0
    13
    I play out in blues jams 3 x's a month, plus gigs with 2 different bands, 1 of them classic rock the other blues. I usually supply one of the amps for the backline at the jams, and I rotate thru different amps. Like Bruce I see all kinds of guys come thru with all sorts of pedal assemblies, they usually sound like crap, but occassionally you get someone that really knows how to use pedals correctly and they can sound really good. In any case, I've never had any problem cutting thru with a small 18 watt type amp. My Princeton Reverb, an Ampeg J20 (think brown Fender Deluxe), a Blues Jr, Deluxe Reverb, or a tweed Deluxe, etc. In fact I usually use some kind of attenuator to keep the volume down a little but let me get the Volume control up into the sweet spot (usually around 2:00). Playing any louder than that is uncomfortably loud for the audience and bar tenders are not appreciative of it. I don't know where you all play where you need more wattage, but it's not small bars and clubs. 2203's? Give me a break, not a chance. Maybe playing some heavy rock you need, or can get away with, more volume. Maybe playing outdoors you need some more, because your sound tends to get sucked away real fast. But in a bar or club that seats 150 to 200 people, playing blues especially, 18 watts is more than enough. If it aint, you're too loud. You may think you sound real bitchin, trust me, the folks out there watching don't think so.
    As far as EL84 amps go, I don't know, I built this one a couple months ago, I don't think it sounds so bumble bees in a paper bag buzzy: YouTube - JTM 18.wmv It can get buzzy, but a tweed Fender can get muddy, that doesn't mean that's all it's capable of.
  28. #28
    Jun 2006
    275
    Received: 5/0
    Given: 2/0
    13
    Quote Originally Posted by hasserl View Post
    +1
    We had a discussion about volume on a Swedish musicians forum a while ago. Most people agreed that about 90% of the concerts they went to were too loud. No-one had ever been to a concert that was not loud enough.
    Pretty much anytime a 10-20W amp is swamped by a bigger amp, it's because the band volume is way too loud.
    OK, a part of the problem is that drummers tend to be Neanderthal style guys whose dynamic range only includes hard and harder...
  29. #29
    Jan 2007
    41
    0
    Keep it up Bruce. I love controversy, strife and offensive remarks. I would rather read an entertaining flame even though I might disagree than suffer that overly obeisant crap which I hate. At least in America we've become way too sensitive and our tolerance to anyone who doesn't walk the thin line is appallingly low. Personal insults aren't acceptable, but hating on fizzy amps should never be a problem.
    I'm a trawler as well because technically I've got a pin-like head and there's nothing I can contribute -- at least for now. And I love just about any noise a guitar/amp combination can make. I'm an old fart too, but the best sound I've ever heard was two well-overdriven channels mixed out of phase. Turns everything upside-down. Wonderfully horrible.
  30. #30
    Jun 2006
    Norristown state hospital
    2,128
    Received: 97/1
    15
    "Get off my lawn"
    Anyway, one of my 18w Marshall style builds has a footswitchable cascaded front end which provides a nice deep rich overdrive without the "buzzy beez"
    It can be done with a little tweaking.
    The rash of high gain 18watters is probably popular for high gain guys who are tired of getting yelled at to "turn it down" at bars and clubs.
    I can gig with an 18w with the right cabinet, like a nice 4x12 and my drummer hits hard.
  31. #31
    May 2007
    pacific north west
    14,556
    Received: 1,563/4
    Given: 1,726/0
    28
    There ARE ways to make EL84's behave. The biggest reason I know of for EL84's buzzy/fizzy reputation is that they grid load very easily causing crossover distortion. Second to that is the fact that most of these amps are cathode biased. So as the amp pushes harder the bias cools. If things aren't set up just right this causes even more crossover distortion. Combine this with high gain and the need to crank them for volume and it's a mess really. The other option is to NOT push the power tubes that hard and generate most of your distortion in the preamp. Either way you get thin, buzzy/fizzy tone.
    Bias on the hot side. EL84's don't seem to mind.
    Use the "Paul Ruby" mod to stop grid loading.
    Don't run plate volts excessively high.
    Use a zener across the cathode resistor to "fix" the bias at the onset of clipping.
    If needed you can use a small conjuctive filter to pull down excessive overshoot spikes on OD. With an 8k priZ a 10k resistor and a 1500pf cap only effects the spike and won't dull your tone.
    Use an OT with some meat on it.
    Since you can now smash the PI and power tubes without fear of crossover distortion or excessive overshoot spikes there is no need for excessive preamp overdrive.
    A good efficient speaker can add more volume than trying to push the power tubes into more watts.
    Ta Daaaa... Now your "pair of EL84's" amp won't offend Bruce
    Uh oh... Did I give something "secret" away like Randy Fay?
    Chuck
  32. #32
    Jul 2006
    179
    13
    I belong to a blues society and we had Nick Moss and the Flip Tops to the club Saturday night. He had a Category 5 amplifier, not sure what model, but he had earlier told me it had a Plexi channel and a JTM 45 channel so I'm assuming it was a pair of EL34's. Long story short, he was way too loud. The soundman didn't even have him in the mix through the fronts and on the dance floor his tone was super-shrill with bottom end flub. I guess it's the Jensen Neo in there, loud but not my favourite for guitar. With the system we have, like a lot of clubs, 20 watts should be more than enough to get that sweet tube sound without messing up the mix. Need more volume?-just turn up the monitors.
  33. #33
    Denver, Colorado
    3,045
    Received: 7/0
    16
    ...Ta Daaaa... Now your "pair of EL84's" amp won't offend Bruce
    Chuck
    Ha ha... I don't think there are any secrets anymore anyhow...
    Cool... I use the zener diodes on the "modded" PA, old school, cathode biased harp amps... well a couple other little tiny tweaks too.
    The conjunctive filter works really well on just about every amp I've tried it on with the largest caps being 2n2 to 4n7 in series with big honkin' 10K higher wattage resistances.... just like Orange did, in the day, with their bad dog 200 watt PA heads.
    I guess that secret got out too...
    Bruce
    Mission Amps
    Denver, CO. 80022
    www.missionamps.com
    303-955-2412
  34. #34
    May 2007
    pacific north west
    14,556
    Received: 1,563/4
    Given: 1,726/0
    28
    Hasserl,
    No one mentioned your amp yet. Sounds great. It's hard to get all the nuances in that vid because it's REALLY compressed. But it sounds very JTM with a hint of Vox top end jangle. Not shrill. If you can't play with that amp, you can't play. Nice.
    I like it better than the Daisy Cutter clip so far.
    Chuck
  35. #35
    Oct 2007
    11,119
    Received: 1,283/18
    Given: 979/24
    26
    Not to agree with Bruce , but I started googling a little and found 2 things
    1) In a page called non other that EHN's AX84 Page , where a fine chap who built all AX84 projects called Nyberg posts some tasty licks, many recorded live, on stage (the best kind ), says the following about the Conjunctive Filter (oh my God, who invented that name):
    The filter definitely smooths out some of the high-end harshness in the EL84 output section,
    Ahem !!
    2) And what would that wonderful cure-it-all 7 wonder be?
    Nothing more than a d_mn low-pass filter: a capacitor wired in parallel with the load, somewhat damped by a series resistor which dissipates harmlessly all that unnecessary high frequency energy (who needs highs anyway?).
    Crossover frequency of a .047/5k6 RC filter? Around 600 Hz. Six-hundred-Hertz.
    Anybody for a "subtle" effect?
    They might just use a car subwoofer speaker, it will roll off at about that frequency.
    3) Does it mean I hate AX48s? No, on the contrary, I love them.
    They sound about 37.455.348 times better than the typical 15W Msh/Fnd/Lny/Pvy/Crt SS "practice" amp, with their typical muffled-and-buzzy sound. (don't know how they achieve both opposite sounds at the same time)
    So: keep on rolling, AX84!!
  1. Ruby EL84
    By Jared Purdy in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-05-2010, 02:04 AM
  2. EL84 Wiring
    By GregS in forum Build Your Amp
    Last Post: 06-16-2009, 03:24 PM
  3. Help with El84 SE design
    By then1xon5 in forum Theory & Design
    Last Post: 12-13-2008, 04:22 PM
  4. EL84 power amp design
    By zikaj in forum Theory & Design
    Last Post: 05-18-2007, 02:07 PM
  5. wich four el84?
    By scole in forum Build Your Amp
    Last Post: 11-25-2006, 03:58 PM
