Echo jet musings.
  • Echo jet musings.
    So while researching the Ampeg Echo Jet EJ12 in for repair, we find that it is an output reverb unit that can be used as a stand alone amp.
    You guys knew that, I'm sure.
    So, has anybody tied the echo unit input to it's own speaker terminals?
    It feedsback when the amp is turned up about half way, but it you pad it down a bit now the unit can be used as an amp with it's own reverb.
    Any of you crazy guys try this way back when?
