Valvestate 8100 Reverb Tank Model Number
  • Valvestate 8100 Reverb Tank Model Number
    What is the best replacement part number for the Valvestate?
    It seems there are two that models around that may fit but I am not sure which. It is eaither the;
    4AB3C1B - two spring Long delay or the
    4DB2C1D - two spring medium delay
    or is it something else?
    Mike
    Each letter or number in the Accutronics part number has significance.
    For example the first "4" means a four spring tank (2 long springs each made up of 2 springs).
    Search the Accutronics site and there is a full listing of all of the codes.
    If you don't know the original tank number, you can more or less figure out what you need by building your own code by what the amp needs.
