Univox guitar circuit schematic
Originally posted by booj View Post[ATTACH]9374[/ATTACH]
[ATTACH]9375[/ATTACH]
I know this is really a longshot, but does anybody have a schematic for this circuit? It uses one 2Sk49 FET, (labeled K49), and one 1458 op amp. The fuzz and phase switches work, but the tremolo and whatever they mean by echo does not.
If you mean a reverb, then you are right, you can't make one with those two parts. However, if they make a variation on the trem circuit where instead of a smooth variation in volume, it becomes just off and on, you get a sort of "repeat" effect. I suspect that might be what the echo does. I think AMpeg or Gibson did that on a couple models.Education is what you're left with after you have forgotten what you have learned.
Originally posted by Enzo View Post...if they make a variation on the trem circuit where instead of a smooth variation in volume, it becomes just off and on, you get a sort of "repeat" effect. I suspect that might be what the echo does. I think AMpeg or Gibson did that on a couple models.
Naturally, you can't do that without a spring reverb tank or some kind of device providing reverberated output.
I think what Enzo is referring to may be the Repeat Percussion thing that Vox had back in the 60's, basically a choppy tremolo effect.
As for the original question, have you tried the Univox Board? Someone here I think posted a link a while ago.
Yeah, but I was speaking generically. Yes, the old Ampeg was modulating the reverb off and on, but they called it an echo. SO by extension, perhaps this Univox is gating something off and on and calling it an echo. But that is merely an opinion.Education is what you're left with after you have forgotten what you have learned.
Thanks for your replys everyone. The deed is done. The guitar works. The echo was an LFO square wave pulsed output. (quieter-louder-quieter-louder) The tremolo was just that. The fuzz was a germanium diode clipper.
I changed all the electrolytics (5), the 2SK49 with a 2N5485, which I installed in reverse to the original part because of the pin layout, and the 1458 IC.
The culprit I think was the 2SK49. I think it had a fractured internal lead.
