Is it possible ? - of course after additional RC filtering etc. There's about 16-18V DC on cathode SE power amp with EL34 or 6L6. The idea is use it for supply JFET before 12AX7 preamp tube or OA based reverb circuit.
Supply voltage for transistor / OA preamp from cathode SE power amp
OK, but be sure to check that it still works when you're overdriving the power tube heavily!
Heavy overdrive can decrease the cathode voltage because of blocking distortion, so the system could go unstable and start motorboating."Enzo, I see that you replied parasitic oscillations. Is that a hypothesis? Or is that your amazing metal band I should check out?"
Originally posted by Steve Conner View PostOK, but be sure to check that it still works when you're overdriving the power tube heavily!
