Hi,
I have been acquiring more gear. This time it's the guts from a stereo radiogram. It works, but I'm interested in a conversion job. I plan to use the PT and chassis to make a PP using the 'Lamington' design by Grant Wills. It will be my second such build. The first is a beauty, albeit a bit buzzy (more work required). with the SE OPTs from the stereo stages I want to build a pair of small amps, similar to a Champ design and fit them into little 10W SS practice cabs which are widely available for next to nothing.
Anyhow, the circuit diagram for the stereo shows the speaker impedance to be 15ohm (yes, 15ohm) and the primary impedance to be 7000ohm. The power valves are 6M5 (~EL80?) which sound awful if I swap them into my Lamington. Now if I was to design my 'Champ-a-like' (or AA4 or whatever) to have an 8ohm speaker, that means that I would have a primary impedance of 3k7ohm, wouldn't I? If so, how do I match an OP valve to the OPT? If I wanted an EL84/6BQ5 OPV, do i just build it and tweak it or can I apply a little science to my choice of OPV? Is there something in the valve datasheet which should be obvious? Plate resistance, perhaps? Does it matter?
Thanks is advance for all your help, it's a pleasure to read these pages.
