Originally posted by motzu
View Post
Beginner, want to build a TAD 5F1 kit
Originally posted by JHow View PostIn case you haven't seen it yet, I found this article interesting on the subject of carbon comp resistors and their "mojo" factor:
http://www.geofex.com/article_folder...carboncomp.htm
Originally posted by motzu View Post...if you get carbon comp resistors with your tube amp kit, use them...
From a practical standpoint, use whatever you have, as long as it is the right power and value. Many ancient CC resistors are out there in the world, doing their job every day.
Thanks!
In the meanwhile, I've started wiring the rectifier tube socket to the input transformer. Here's a TAD picture of how it's supposed to look:
What I'm not clear on is this: the layout says I should wire the two yellow wires to pins 2 and 8, and the two red wires to pins 4 and 6. But they don't say which of the pair goes where. I'm assuming that it doesn't matter? Any of the yellow wires can go to either pin 2 or 8, and any of the red wires to 4 or 6?
Originally posted by motzu View Post...Sorry for the dumb question.
I see that you've got some fingers pointed at you in this thread. You'll probably be zapped at some point. Just make sure it only one finger tasting the Bzzzzt. Always measure with one hand on your back.In this forum everyone is entitled to my opinion.
Well, I've built it and it works. Thankfully no debugging was necessary. I've measured the DC voltages inside and they're about 15-20% less than what the schematic says they would be, but the TAD schematic says that a +-10% difference is fine, and the original Fender schematic allows for +-20% so that should be OK.
Thank you to everyone who answered my questions!
