Results 1 to 2 of 2
Thread: 2 Stroke Build completed today, Question
    Junior Member rsmalling's Avatar
    May 2010
    Southern California
    10
    0
    Just tested out my first build, It's called the 2 stroke Amp from a Dave hunter Book. I think everything went well.
    How much volume should I expect? Maxed out it has a great tone and is starting to get loud. At halfway it seems to low, you could easily have a normal conversation with someone, I know it must have more in there.B ut I have nothing to compare it to..... I have spent a few hours double chking connections.
    el34 12ax7 and a 5y3gt. It's a real similar layout to a 5f2 I believe. 10 watts with the el34. I was using a 1 12 16ohm eminence tonker light.
    Edit: Everything is as it should be, its a good build. Talked to some other guys and compared notes.
    2 stroke Amp Build 5-2010 pictures by rsmalling - Photobucket
    Thanks for any help, comments or insight.
    Rob
    Rob
    Supporting Member tubeswell's Avatar
    Feb 2007
    Wellington NZ
    4,202
    Blog Entries
    1
    Received: 133/0
    Given: 45/0
    18
    You might get 8W with 1 x EL34 in SE Class A. Either way it won't be much louder than the 5W one.
  1. Problem with Two Stroke Build
    By Schnizz in forum Debugging Your Build
    Last Post: 07-01-2010, 05:52 PM
  2. Replies: 13
    Last Post: 10-19-2009, 02:20 PM
  3. Dave Hunter's Two Stroke: Questions About Possible Build
    By Johnrcurry in forum Build Your Amp
    Last Post: 03-22-2009, 03:36 AM
  4. Two Stroke Boost Switch Question
    By Tremolux55 in forum Debugging Your Build
    Last Post: 12-03-2008, 06:02 PM
  5. first build completed -thanks to all!
    By pbreyfogle in forum 5 E 3
    Last Post: 06-30-2007, 07:09 AM
