Hello to all,
Got this "hi-gainiac" on repair.The owner accuses a sudden loss of sound after approx.1/2 hour of playing.I opened the amp,went directly to the output stage and replaced the 100 Ohm/5W "white coffins" (one of them was showing no DC resistance) with 470 Ohm/2W as it's said to be "that's more like it for a 6L6".
Replaced the output tubes with a fresh JJ Tesla paired quartet.Checked the OPT,looks fine when DC resistance is measured across all the windings.Verified all the fuses,they're OK.
The problem appears when I power up the amp:the output signal is very low and I can clearly hear the mains XFMR "singing",depending on the input (guitar or jack/finger source) level.
What should I look for?
(I'm aware on the several steps that should be taken in such situations for nailing down a presumable power supply issue but I hope for someone's punctual answer since this specific amp isn't repairing-friendly at all:big PCB,etc,etc.)
TIA!
Regards,
LB
TIA!
Regards,
LB
