Originally posted by Jimmy74
View Post
I know it's a bit pedantic, but we have to be careful with terminology, or we'll get mixed up. Those were not "ground mods" in the sense that they did not change what the grounding does. They just forced various signal voltages to be equal to the local ground voltage, whatever that is. Let's call them "temporary signal shorts" instead. And let's not call them "mods". Otherwise, the ever-present cadre of mod-hungry amp beginners who sift the internet ever-finer with google will be screaming about amp mods not doing anything.
And no, you don't have to remove them first. They were intended to connect places with voltages that should already be at 0V dc to ground, which should be 0V dc. Only any signal voltages were zeroed out. So for this small, tiny step, they do not need removed. Or they could be removed. Makes no difference to the testing.
I guess that these voltage readings are taken by placing the tester leads across the resistor?
This test is looking for the possibility that what should be "ground" and the same voltage of 0.000000V in both places is in fact messed up some way and the two places are not at the same voltage. This could theoretically cause a condition which would fit what you have described as the problem.
So you do not use tester leads across a resistor, you touch one lead to the ground side of two *different* resistors.
Question: I suppose I should take out the TEST III short before placing the short from pin7 V12 to the 4.7k resistor?
I have a great deal of apprehension that what I'm trying to tell you is not getting across, and as a result the chance for error is high. I'm trying not to have to go do a schematic drawing for each test, as that's going to be a huge PITA and time taker.
