Ok the center hole of V12 is just a junction for the various shields and the ground wire which goes to the reverb board.... which is grounded to the preamp board via 2 shielded wires. Therefore the center hole of V12 is not grounded at all to the chassis if there are no wires attached to it or if I lift the wire going to the safety earth point. I will separate the reverb section from the junction on the preamp board and attach the shielded wires right to point B, that way reverb ground does not have any junctions with the preamp board ground and goes straight to point B. I have tied the HV CT right to the negative lug on the main filter cap and passes a wire from there to point B. I will do the same with the preamp filter caps and the reverb HV cap. I'll leave the heater CT and power transformer shield grounded at the same place for now and see what happens. Do you still advise using the input jacks ground source as true ground and not the main safe ground point?
thanks
thanks
