Hi all! I'm new to the fourm and saw a lot of posts about Dave Hunter's Two Stroke. I just finished a build and it is working well with only one problem. When I turn up the volume above about 3/4 I get a rapid thumping in the speaker. It gets louder as stronger as I continue to turn it up. It is unaffected by the guitar or the tone control. The noise itself stays at a constant low pitch. Any ideas?
Two Stroke thump
What FYL means by that is make sure the high voltage filter caps are connected correctly to the OT, the dropping resistor to the screen supply and the dropping resistor to the preamp B+ supply.
Motor boating is commonly caused by the filter caps not decoupling AC from the B+ rail... bad filter cap, soldered in wrong, not grounded.. etc etc.
The 8uF @ 450V and the 16uF @ 475V are the suspects. Warning: these parts can store a charge and shock you when the amp is off and unplugged. If you are unfamiliar with this, search for threads about discharging caps.
You can verify the ground connection (with power off) by ohming the minus side of the caps to the chassis. Verify the plus side simply by measuring the voltage, it should be +250V to +450V or so. The parts could be defective but pass these tests so you may need to order some spares.WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personnel.
The grounds on those caps read zero resistance and they read around 330-350 vdc. Does the proximity of wiring to the tubes to the positive leads from the large caps have an effect like this? (they are very close, less than 1/2 inch) I do have spares for all the electronic components (resistors, caps)
I don't think your problem is caused by wiring. You might try temporarily connecting a spare 8uF cap in parallel with the 8uF cap in the circuit. (observe polarity) It should either stop the thumping or make it thump at half speed if we are on the right track.
Another possible cause is the feedback around the output stage, but normally it wouldn't be affected by the volume control. There is a 68K resistor that goes between the speaker jacks and the 12AX7. Try disconnecting one end of that resistor to see if that stops the thumping.WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personnel.
Originally posted by MJEnzen View PostPlease excuse my ignorance. Which would that be on this schematic?Building a better world (one tube amp at a time)
