3M Wollensak Reel To Reel Recoder W / Tube Amp
  • 3M Wollensak Reel To Reel Recoder W / Tube Amp
    This is a seldom seen less heard of guitar amp , one that can rival any of the classic tube guitar amps that were around at the same time with the same over all power.
    There were two models and one came with a 100 RMS Watt tube amp using 6L6's !
    Heavy hitting electrified harp (harmonica ) players know about these little darlings too
    The smaller wattage amp pumped about 10 to 15 watts with smaller tubes .
    All in all a sweet little eye and ear delighter that will please the need for tone addicted guitar freaks
    Easy :
    Hurricane Ramon
    Hey, I have one of those!! How cool would it be to somehow set it up to have a slapback tape echo?!? Never thought of that...
    Don't believe everything you think. Beware of Rottweiler. Search engines are free.
      Slap Back N'stuff
      Hello Riz :
      Would be possible if you mounted an other playback head , you see when a two head recorder like this one records it uses the same hear as the one for playback so you need two heads -
      one to record and one to play it back .
      The other head of a two headed recorder is an erase only head and does nothing in regards to record or playback .
      Lots of Hendrix devotees love these little recorder's amps and just use that and junk the rest so finding a second head would start the process
      Easy
      Hurricane Ramon
