Laney VC30 run away bias
  • Laney VC30 run away bias
    Have a Laney VC30 on the bench. Owner had been powering it with generator and then HT fuse went. Reports that after replacing fuse, 2 of the 4 EL84's get hot and volume drops. On bench I checked bias on all 4 EL84s. Two are at about -15mv and the others start at about -18mv and climb gradually to -250mv (cut-off) or more. Replaced a couple suspect leaky caps which made very little difference. Not that familiar with cathode bias amps. Any suggestions?
    the control grid on the power tube(s) is not seeing ground.
    Gary Moore
    Moore Amplifiication
    mooreamps@hotmail.com
