Brownface/ silverface cab build: info pls!
  • Brownface/ silverface cab build: info pls!
    Hi folks, long time since posting on here- greetings to y'all.
    Now, I need to build a brownface type cabinet, ie a 'std' fender type with the amp/controls on front. The only info I need is the angled section (ie on the front at the top, where the amp/controls sit). Does anyone know what this angle is? also is a std chassis H for these types 2", or does that vary? Maybe someone has either one of the silver/blk/brownface cabs (assuming the angle and chassis H are a std dim/ the same) or a chassis to hand?
    Fwiw I'm making a 23.5" x 18.25" x 9" 2x10 fingerjointed pine cab. Should be easy enough without the tweed 1.75 facia strips to rout in/add on.. albeit I can't figure out how I'd cut the angled ~3/4" off tbh! but I'll cross that bridge later- Im sure I can do somehow.
    thanks capt.
    Can no-one help me on this? there's no way to find out apart from asking somewhere like here.
    If its not clear what Im after.. its the sloping bit on a fender amp, ie the sloped/ angled top part on the face of the amp.
    thanks.
      Check your PM's
      Bruce
        According to this item, the angle is 25º
          That's terrific help- thanks so much!
