Results 1 to 22 of 22
Thread: Choosing central bias
    Junior Member
    Jun 2010
    20
    0
    Guys,
    Posted earlier about my silly ideas to build an amp... got schooled, went away and did it all again properly. Just a query about the biasing.
    I understand that you can run the tube in central, hot, cold and so on to get the drive tones/types of drive you want, but I wonder what is the actual value of central bias? Is this found under typical characteristics on the datasheets or is this an agreed upon value?
    My first stage is using a 12AU7 hopefully running on center biasing. So what kind of number should I start by using? Of course, I can fiddle with it afterward. I was also wondering about using diodes (probably more than one) to regulate whilst achieving full gain, is this worth it?
    Thanks!
    Valvulados.com jmaf's Avatar
    Apr 2009
    Brasilia
    1,374
    Received: 42/1
    Given: 39/3
    13
    There is a range where anything between the max(cutoff) and minimum bias(plate bbq) voltage is OK, then you choose somewhere in between that range according to your needs. Center would be somewhere in the middle, I guess.
    How do you find the approximate middle? For guitar amps, techs normally shoot for 70% of full tube dissipation. So, if you have +B voltage and you know the tube's wattage, bob's your uncle: you know the 100% current. Take 70% from that and you've got the current to shoot for.
    This normally isn't done for 12AU7 tubes though, this is power tube stuff. For preamp tubes their maximum dissipation is 1 to 3 watts max, so you're not really worried about quiescent current, but about tone shaping, frequency response, etc, instead.
    Good luck with the project.
    Senior Member Wilder Amplification's Avatar
    Oct 2009
    659
    11
    "Center bias" on a single ended preamp stage would be the bias point that gives 100% symmetry at the output (i.e. the point in the positive swing where the tube hits cutoff is exactly the same as where it hits saturation on the negative swing). However there's really no way to achieve "center bias" on a SE preamp stage due to the fact that the grid curves are not linearly spaced. You can get close but not 100% symmetry.
    If you draw up a load line it becomes pretty easy to see.
    Jon Wilder
    Quote Originally Posted by m-fine
    I don't know about you, but I find it a LOT easier to change a capacitor than to actually learn how to play well
    Quote Originally Posted by JoeM
    I doubt if any of my favorite players even own a soldering iron.
    May 2007
    Silicon Valley ; USA
    1,097
    14
    Quote Originally Posted by snowballfight View Post
    Guys,
    Thanks!
    Ya, it is worth it. To bias the first gain stage, start with 2 1N4007 in series for a total forward bias of approx. 1 volt. The remaining preamp gain stages, use a single red ultra bright led for a total forward bias of approx 1.7 volts.
    good luck !!!
    -g
    Junior Member
    Jun 2010
    20
    0
    Thanks, I was thinking of doing something similar already. Is there any way of putting in the idea of red LEDs into the valve power circuits without actually affecting values? What I mean is, I was trying to use LEDs to quickly show that the valves are recieving power (ie - wired correctly and on = LIGHT) but without changing the characteristics of the B+ or cathode voltages. I could put them in the heater circuits but that wouldn't be a direct measurement on voltage travelling down B+.
    Junior Member
    Jun 2010
    20
    0
    Yeah, this is what I gathered - do you know of any threads that describe that process of mapping audio/AC curves onto load lines around here? I've got Merlin Blencowe's preamp book infront of me as reference, but this is the one section of the biasing I really don't get. I understand how to change it, and what affects this would encur but not how to plot it to get the p-2-p voltage swing....
    Hope you can help?
    Oct 2009
    659
    11
    Here is an example load line for the front end of a Marshall Super Lead Normal and Bright channels. You can see how the different cathode resistors give each stage a different bias point -
    You can see on this load line, the 820R cathode resistor appears to provide the closest to "center bias" as the grid curves that exist between 0 and -2V seem to have a "linear" spacing. Of course this only holds true with a 2Vpk-pk input signal (1Vpk or 0.707Vrms). Once the input signal swings higher than that, it will push the tube into saturation LONG before it pushes it into cutoff, and you end up with the asymmetrical output. For a front end 1st input stage with a typical passive guitar pickup though, this input voltage is more than likely never reached.
    Now for push pull output sections, you have to do what is called a "composite load line". This is where you draw the load line for 1 tube, mark the bias point, then take that same load line and "inverse mirror" it (i.e. copy and flip it), then line the bias points on the two load lines up. One of them gets flipped to reflect the fact that it operates out of phase relative to the other tube.
    Here is one I did for a KT88 amp using a 5K plate to plate Z with a 600V B+ and a 300V screen voltage -
    You can see here how the load line makes the two tubes look like 1 big tube that can swing between zero and double the B+.You can also see that the ends of the graphs line up with 1200V, which in this case is double the B+. In reality though, it can only swing to the voltage at which it crosses the "Vg1=0" line, which in this case would be down to 125 volts on each side of the swing. This would amount to about a 950Vpk-pk swing.
    If we increase the screen voltage by a factor of 50 volts or so, we can shift the curves up so that the load line is crossing the Vg1=0 curve just below the knee rather than right through the knee as it is doing in this example. Crossing the load line just below the knee will yield maximum possible voltage and current swing and therefore maximum power transfer.
    This load line also applies for a 4 tube amp...but you double the current scale on the vertical axis.
    Jon Wilder
    Junior Member
    Jun 2010
    20
    0
    Ah ok I see, this has cleared up alot! I'm taking the area with linear-ish spacings as the area to head for, and the center of that is about central bias. Looking at my JJ tube datasheets for an 12AU7, first stage tube, I should be heading for 0-Vg-8V and centering at -4V.
    Only problem here is that this gives a voltage of around 130V - is this not a little low?
    Old Timer
    Jun 2006
    3,315
    Received: 1/0
    17
    Snowball fight wrote: "Only problem here is that this gives a voltage of around 130V - is this not a little low?" A 12AU7 draws a lot more current than a 12AX7, so runs at far lower plate voltage in a similar circuit, e.g. in a middle of the road preamp triode with 1.5K cathode resistor & 100K plate resistor (not that I am suggesting those values, they're just for illustration purposes) that 130v on the plate would equate to around 435vdc at the B+ rail feeding the plate resistor. In the same circuit we around would see around 295vdc on a 12AX7...so in the grander scheme of things 130vdc is really quite a high plate voltage for a 12AU7. I would perhaps build in a little leeway so that you can also try 12AY7 & 12AT7 and go by ear.
    Junior Member
    Jun 2010
    20
    0
    Yeah I have been toying in my mind between the 12AU7 and 12AT7 and I don't really know which to choose. This is for a preamp for bass so I'm not so concerned with the high overdrive sound of lots of 12AX7s or whatever, I heard this tubes are nicer for clean tone. If I've only got a B+ of around 250VDC to play with then you mean I should be down lower? Sub 100? In terms of leeway, this is still on paper, so anything is up for change :S ha
    Old Timer
    Jun 2006
    3,315
    Received: 1/0
    17
    "If I've only got a B+ of around 250VDC to play with then you mean I should be down lower? Sub 100?" Well, you won't really be able to avoid going lower unless you use a very high value cathode resistor (>2.7K?) & a low value plate resistor (I'd start out aiming around 100K as the smallest value at the plate).
    Why only 250vdc available at the B+ rail?
  12. #12
    Aug 2006
    Lancashire
    649
    Received: 16/0
    14
    I would recommend 12AU7 as it has a much more pleasant grid-current (overdrive) characteristic than the 12AT7. 12AT7 tends to get kinda fuzzy if you get too close to overdriving it, because it has way higher grid current, and it starts flowing sooner too.
    You can put LEDs in series with the anode resistors of the preamp valves quite safely, which has negligible effect on operation. It's trickier with power valves because the currents are higher.
    See here for some LED ideas: http://www.freewebs.com/valvewizard2/ampwithLEDs.jpg
    Also, you might like to try my load-line plotter program. Just plug in values for HT, anode resistor, cathode resistor, and view the load lines instantly (preamp valves only). Where they cross is the bias point. See bottom of the page: The Valve Wizard
  13. #13
    Junior Member
    Jun 2010
    20
    0
    Well since this is a stand alone preamp, I was trying to minimise the size/weight of the power transformer. Rectified, the one i'm looking at states that it should give 250VDC. Think its a 190-0-190 @ 80mA winding. Is that too small?
  14. #14
    Old Timer
    Jun 2006
    3,315
    Received: 1/0
    17
    No, that's pretty substantial for a preamp, in terms of current capacity anyway, how many preamp tubes are you anticipating? If you aren't drawing significant current from the PT, then your B+ may end up higher than you anticipate, not necessarily a bad thing.
  15. #15
    Junior Member
    Jun 2010
    20
    0
    Erm. 1x12AU7 and 2x12AX7s. Might even bypass a tone stack for now at least if I've got the power amps EQ bands, if that makes a difference to the loading. A lighter load means its ratings will go up? How can I practically measure that? I say this because I'm not really looking for high end gain, more a full tone and little amount of tube attack. I'm not a great fan of bass overdrive atm.
  16. #16
    Aug 2006
    Lancashire
    649
    Received: 16/0
    14
    You don't really need to, it makes little difference to the operation of the preamp. It's not like a high voltage means you suddenly have to build a Soldano or anything!
    If the transformer is 190Vac, then the max DC voltage will be 190*root 2, or 266V. The more you load the transformer the more this will fall, and according to the manufacturer you expect 250V at full load. Therefore you can be pretty sure that whatever you do, your HT voltage will be between 250V and 266V, which is a mere 6% variation! Don't worry about it.
  17. #17
    Junior Member
    Jun 2010
    20
    0
    In response to MWJB earlier; "Well, you won't really be able to avoid going lower unless you use a very high value cathode resistor (>2.7K?) & a low value plate resistor"
    Whats wrong with having a steep load line on the 12AU7, say with 47k to get to the bias point with a higher voltage? It would mean a cathode resistor of, I think i had this at one point, 4k? Would this actually damage/affect the tube?
  18. #18
    Old Timer
    Jun 2006
    3,315
    Received: 1/0
    17
    No, it won't damage the tube, it might sound harsh though? Try it & see.
    Normally preamps are designed around cathode & plate values that give the desired character, then tweaked as far as plate/B+ supply voltage, bias current typically ends up as what it is after the other perameters are decided.
  19. #19
    Oct 2009
    659
    11
    In playing with the 12AU7 load line that's about what I got too. They're not a very high gain tube.
    In this load line I drew up for one, at a supply voltage of 250V and a plate resistor of 25K it gets me a gain of about 12.5. An 820R resistor will bias you right up to where you wanna be a -4V in this scenario, which is as close to "center bias" as you're gonna get.
    Jon Wilder
  20. #20
    Junior Member
    Jun 2010
    20
    0
    With a gain of only 12.5, am I pretty much good to couple that directly with the second stage? through a 22uF, perhaps a little lower (10uF), and relatively low kilo-ohm resistor.
  21. #21
    Oct 2009
    659
    11
    Not sure why you'd wanna do that, but that all depends on what your actual output signal amplitude from that stage is. The gain just determines the "input sensitivity" of the stage (i.e. how much input signal it takes to drive the output signal to a given amplitude).
    Using a low value leak resistor on the proceeding stage will load the driving stage's output somewhat.
    Jon Wilder
  22. #22
    Aug 2009
    Melbourne, Australia
    277
    Received: 2/0
    Given: 7/0
    11
    I've just built a 12AU7 first and second stage cascaded pre-amp. ~ 250V B+ (depends on what else I run from the power supply as I play around with other channels), 47K anode resistors. For the first stage I am biasing it with a blue LED, giving 2.8V bias, and a voltage gain of ~12. Second stage has Rk = 3.3K, 10uF bypass cap, giving 5.9V bias, and voltage gain of ~11 (as this pushes into the non-linear area of the grid curves). I chose this bias for symmetry of clipping/grid current, and tweaked the bias to get this balance using a CRO and signal generator. The slight compression from this grid curve bunching sounds pretty good IMO. I put a 1M pot between the stages, using it as the second stage grid leak. I designed this pre-amp to be a 'clean' channel. I'm really happy with the sound, and it would really suit a bass pre-amp I think.
  1. Choosing an output transformer...
    By alchemy in forum Theory & Design
    Last Post: 06-04-2010, 05:12 AM
  2. Choosing an output xformer
    By CitizenCain in forum Theory & Design
    Last Post: 01-20-2010, 08:32 PM
  3. First amp, need help choosing which.
    By StigF in forum Build Your Amp
    Last Post: 08-25-2009, 07:13 PM
  4. Choosing OT from OT's
    By petemoore in forum Theory & Design
    Last Post: 01-25-2008, 08:50 PM
  5. choosing tubes help?
    By jaypaul in forum Tubes (Valves)
    Last Post: 09-20-2006, 12:39 AM
Tags for this Thread
