Silverface Bassman 50 questions
  • Silverface Bassman 50 questions
    Is this a 1972 amp with AB165 circuit? See pics...the chassis number is A66027.
    And one transformer number is 022871, 606-2 03
    Also...is everything original?....the main filter caps are all original brown Mallory.
    Will it damage anything if I just play the amp as-is, or do I need to change some
    components ? It plays great with no issues but I want to protect it.
    All advice appreciated......I just play my guitar through it, no bass.
    Thanks in advance
    DocClick image for larger version
Name:	Patty at camp  Fender Bassman head 033.JPG
ID:	862654Click image for larger version
Name:	Patty at camp  Fender Bassman head 034.JPG
ID:	862655Click image for larger version
Name:	Patty at camp  Fender Bassman head 036.JPG
    Its not the AB165, but its not hard to make this circuit perform better than it does stock.
    http://www.schematicheaven.com/fende..._bassman50.pdf
    For starters, the .002u caps on the output tube grids need to go....along with the caps across the plate load resistors on each channel's input stage. Its likely the lead dress will need to be tidied up after removing those caps....it may oscillate.
      Thanks Gtr_tech..........so is the AA371 ?
      Doc
        Nope...its a Bassman 50.
