'59 Fender Bassman Reissue low volume
  • '59 Fender Bassman Reissue low volume
    Hi.
    I have a fender bassman reissue, and it is outputting only the tinyest bit of volume. I found that the two power tubes had blown resistors, so I replaced them, then got new power tubes, since those had also been damaged. I had the preamp tubes tested, and they seemed to draw power fine. However, I am still getting only a tiny bit of volume. Any suggestions?
    Thanks a lot.
    Saul
    Welcome to the place.
    Which resistors did you replace? R33 and R34? Have you checked the high voltages in the power supply? Have you checked the speakers?
      yeah! I got it figured out! I had replaced R33 and R34, but after that was fixed, it was, as you suggested, also indeed a speaker problem. Thanks so much for your help.
      Saul
