wheres the coil estimator
  • wheres the coil estimator
    does anybody else have trouble opening this page
    http://www.salvarsan.org/pickups/Coil_Estimator.html
    I can't open it either.
    I guess the server is down or they took it off.
      is there anyway we can get a program like this now this on is gone down
      Salvarsan don't accept PM
      i know its just math but its a good starting point of how many winds +/-
      a quick & easy place to start winding
      any help would be appreciated
        So there's a difference in approach, while some want to calculate ...then wind.
        Others do the opposite, wind and document the results.
        (the latter is much more fulfilling, and really doesn't take that much more time)
        I did the second choice and I'm glad I did. No offence to anyone, just saying.
        -Brad
        ClassicAmplification.com
          i do wind & document . but lately i have been experimenting with awg 43 at a low wind & before 10000 turns of 43 would be around 10k but using 43 & around 6200 winds it figured it would be 6.2k but it was about 5.7k
          but before i would always come close to 1000 turns equal 1k dcr
            The last coil estimator is at the old link but may not last long since the server will be shut down eventually.
            Save a copy for your own use.
            Coil Estimator
            For a brief bit of amusement, go to the home page at:
            BSOD
              thanks a million
              i did look at that , what going on with that
                Okay, the permissions are set up correctly so anyone can read from
                The Coil_Estimator estimates windings count within 10% at worst.
                  Coil Estimator
                  BSOD
                  Thanks for setting this up!
                  What's the recommended procedure for saving a copy?
                    Huh! Seems to work just fine saved as a web archive!
                      load the page
                      then up top click File scroll down to "save as"
                        A radical idea; why didn't I think of that?
                        (Don't answer that...)
                          That's how I have been using it. I saved a copy of the html file and even added my own bobbin sizes.
                            BSOD
                            I'm glad I never had to look at that BSOD! (though every once in a blue moon I get one of these kernel panics):
                              Yet Another Coil Estimator
                              The Coil Estimator has been revised for better ease of use.
                              There is slightly less clutter, you can edit the bobbin dimensions,
                              and it shows estimates for several different fill factors.
