If you are going to do this test properly make sure the foil caps have the outer foil oriented the same to ground. The outer foil end used to be marked on foil caps but no longer is. Orient it properly and the signal flow will be shielded better and will reduce noise. Also there is a slight difference in resistance with orientation which in this test could affect treble bleed.
Here is a simple way to test it.
