balanced audio question
  • balanced audio question
    howdy all!
    how do I split a std. 10k unbalanced commercial audio signal into a combined signal (mono) + std stereo signal for 2.1 amplification? The mono signal will then go through the (magic) Linkwitz Transform circuit.
    is a resistive mixer AOK or should I use an isolating transformer like this Edcor unit:
    EDCOR - S2M
    to make the combined (mono) sub feed and use the front end stereo signal to go to the mains?
    the 2.1 unbalanced will then have the mains stereo + LT mono sub -> 600ohm balanced, and fed to the (3) amps
    this is likely simple but I my brain isn't working currently...
