So I tried to power up my latest project today - 5F6A Bassman.
I powered up with no power tubes with my light bulb limiter and no problems. As soon as I put power tubes in and powered up, my limiter is glowing bright and I noted a couple things:
- the voltage on the power tubes is low - between 225-230V biased at about 45 ma
- the preamp tube filaments all stop glowing as soon as I switch it from standby
- the pilot light dims when it is switched from standby
- the fuse doesn't blow, but my limiter indicates a short
I double and triple checked all the wiring before I powered up and everything matched the schematic and layout. I did make a couple of small changes to the classic circuit, though:
- made the bias adjustable by adding a 50k pot with 15k resistor in the bias circuit
- I am using a Weber Copper Cap rectifier
- the OT is a Heyboer 2/4/8 ohm multitap with the 8 ohm tap used only, the 2 and 4 ohm taps are not connected (but the wire ends were covered with shrink tubing and tape to prevent any shorting)
I am going to start troubleshooting it, but was hoping maybe someone would have some insight into what potential issues may be present to make the process a little easier. I know there's some really experienced folks on here and any input would be much appreciated.
