Traynor TS120B bass amp
  • Traynor TS120B bass amp
    hi all
    I have a traynor bass amp TS120B I am trying to repair
    The amp powers up ok but the output is garbled mixed with 60 cycle hum
    The xlr output from preamp alone is distorted and hums
    I replaced TL071 and TL072 in preamp
    there is a switching IC TL604 that i did not change as I could not locate one to purchase
    Transformer output is 36 volts AC steady
    The amp rails should be 50 volts + and -
    however the test on the output of the bridge rectifier gives me plus 50 volts
    and minus 32 volts
    I changed the rectifier but the readings are unaffected
    Output Transistors were removed and ohm meter tested and seemed to check out correctly
    I think this is a preamp problem but not certain of that
    however I am puzzled at the low minus voltage reading at the negative rectifier output
    any thoughts on a possible cause for the amplifier problem or cures ?
    thank you in advance
    regards
    robgrif
    The filter cap for the -50V is probably bad. Otherwise something is loading down the -50 supply. If you measure AC at the outputs of the rectifier you will probably see much more AC on the -50 than on the +50 side.
      traynor ts120b bass amp
      thanks for the tip you were right on the mark
      replaced the cap and amp came back to life
      voltages now are correct
      thank you for help
      regards
      robgrif
