X2 capacitors for Rivera amps
  • X2 capacitors for Rivera amps
    Hi Guys,
    Fixed an Rivera Hundred 2 Twelve sometime ago, with a blew supression cap on the PT's HV tap. Schematic calls for a 0.047uF 440VAC, but those caps seem made of unobtainium...at least here in Brazil, although had no luck looking on ebay either.
    Just used a regular polyester cap, but now owner complains about radio picking/general interference, and noisier reverb.
    Would be that cap so important to affect the reverb circuit ?
    250/275VAC types seems more available. Would they work fine (in this supression duty) wired in series ?
    What would be a source for them ? (since Riveras blow them very often, stock some would be a good idea).
    thanks,
    roberto
    Originally posted by Roberto Lasco View Post
    Hi Guys,
    thanks,
    roberto
    You can use capacitor 0.022-0.1 uF of any type, but it’s voltage must be more than 220V (standard AC rms value in Brazil) multiplied by 1.41 (in order to get amplitude value), that is more than 310V.
    I prefer 600V. You can find cap at Digi-Key, Mouser, Farnell, etc…
    Radio picking and general interference have as a rule another source - bad contact or bad solder point at amp’s input circuitry or GND.
    Reverb noise is another story altogether…
      This cap don't sit in the (wall) AC line (BTW, Brazil is 120V); but shunting the bridge rectifier on the high voltage secondary tap, which sees about 340V. I already used an "any type" cap (polyester, 630V), apparently with poor results...
      Rivera construction board won't lead me to think I had a bad solder joint, besides problem seems to arised after this cap change.
      So I want to revalidate my questions and add one: what if I use the 250VAC X2 type in the primary of PT ?
        Just a correction: cap is not a 0.047, but 0.01; and PT primary already use a supression cap...
        Found today at ebay those X2 440VAC caps, but at 0.068; would it be suitable subs ? Not sure about the theory behind that supression job. Where's RG when you need him ?
