How to change truss rod nut???
  • How to change truss rod nut???
    I have a fender standard strat neck and the truss rod nut is flat
    How can I get it out and change it with the new one???
    Please help me out
    Thank you all in advance
    You might try a long nosed pair of pliers, but, you will certainly have to use a litle counterpresure on the neck to loosen the grab (friction) of the nut onto the washer. Sometimes it's just plain impossible to do the job, and you have to take the whole rod out.
      I was under the impression that it was an allen key that was needed on these
      Mick
        Mick
        Yes, but if the hex key is rounded, there isn't much choice!
          Hi there
          What I did was using some power glue on the tip of Allen key and it worked!!!
          I adjust the truss rod now to 011 set
          To change the truss rod nut now I know that I have to remove the wooden ring,
          Or the nut doesn't come out
