Help solving Fender Hot Rod DeVille 410 reverb problem
  • Help solving Fender Hot Rod DeVille 410 reverb problem
    I just installed a new reverb tank into my HRD 410 when I turned the amp on I played it for about a minute and the reverb vorked fine then the reverb cut off and now I can't hear the reverb at all
    because it worked I'm sure I plugged the reverb tank the proper way and that the reverb tank works
    when I shake the amp I can hear the spring touching and can control the volume with the reverb knob so the reverb return path works
    also I don't believe that the input coil in the revrb tank could burn out after a minute of playing
    what could this be ?
    it worked for a minute then died ?
    Make sure the tank is the same model as the original.
    Measure the input connection in the tank with a multimeter. Must be somewhat below 2000 ohms.
    If you find continuity, the problem is elsewhere: poor contact in the connector, a problem with the reverb driver...
      and the values on the input and output are right
      just can't figure this out
      this is the flakiest amp Fender ever made
      I still regret I got rid of my Twin Reverb
        The reverb circuit drive & return are based on an opamp circuit.
        Look at the schematic at IC U2A.
        Pin #3 is TP 19.
        Verify that you have a 1.13 Vac signal entering the IC.
        Then test pin #1. TP 20.
        That is the IC output.
        The output should have a gain of 10.
          well this amp is a major flake lol
          I connected the reverb input from the amp to my stereo and played a few strums very strong signal is coming out it almost busted my stereo
          after that I plugged in an output from CD player to the reverb return of the amp and it played also the reverb knob works
          Now I connected the reverb return cable of the map to the reverb tank and to the input of the tank my cd player .. the tank works I can hear the music with the reverb effect
          so I connected everything back as it suppose to be and now the reverb works
          I have to wait till it stops working again so I can trouble shoot it
          very strange
          I also tried to rock the reverb op amp and it seems to be firm not lose
          Maybe Fender should rename it to Flakester 410
            Nice troubleshooting!
            Sounds like a flaky cord.
            Check continuity from end to end & flrx the cable.
              Was the old tank working? If so, like JP said it is most likely a cable or connector problem.
              If you replaced the tank because of a reverb problem, it could be the tank was not the problem and there is some other intermittent fault.
