In a speaker box that is more or less mated to the head (or combo Box) it will work with forever.. Could 3 equal ohmage woefully underpowered cc resistors wired with 1 speaker, "S/P" be made to create some in a reactive way? More or less a half-volume switch. CC does "stuff" if pushed too hard, right?
Distorting CC resistors
you would need some hefty wattage resistors for most amps (20? 30? 50? 100 watts?). Remember, you're talking about wasting power, converting it into heat. The carbon comp "resistor distortion" idea is really better applied to the amp's circuitry and even then, only really works where you have a large voltage swing at a power dissipation level somewhere near the resistors own limit.
Of course, some people will swear that they can hear a "browner" sound in their carbon comp modified TS-9's or 10's... hey... maybe so...
Originally posted by dave////irongaterThanks Corona, but is anyone out there from the CC distortion thread from about a year ago?
I'll help if I can.
The amount of distortion you can get out of CC resistors nondestructively is limited. The distortion is caused by the resistance changing in response to the voltage across the resistor. To get much distortion, high voltages are required, on the order of hundreds of volts of signal. Speaaker outputs are generally much lower than that, and the proposed 4 ohm speaker load won't generate much distortion. Some, and measurable with the right equipment, but not a lot.Amazing!! Who would ever have guessed that someone who villified the evil rich people would begin happily accepting their millions in speaking fees!
Originally posted by R.G.... The amount of distortion you can get out of CC resistors nondestructively is limited. The distortion is caused by the resistance changing in response to the voltage across the resistor. ...
Shea
Originally posted by dave////irongaterThanks RG & Shea. Bad idea then? Would you have an idea on a starting point for a AB165 lightbulb? Parallel, right? Thanks in advance..
Also, you might try using some fixed resistors to limit the effect of the lightbulb, if it becomes necessary to protect your amp's output circuit from extreme loading or underloading. For example, if you connect a lightbulb in parallel with the output, then putting a resistor in series with the lightbulb would prevent shorting out the output when the bulb is cold. And if you connect a lightbulb in series with the output, then putting a resistor in parallel with the lightbulb would limit the max resistance when the bulb is hot. I don't know if those things are really necessary, but it's something to consider.
Shea
10W CC's?
Originally posted by dave////irongaterI was thinking three 10 watt 4 ohm resistors in a 4 ohm box for a Bassman. To do anything the ccs have to be straining.
RE
